| tomcat-juli.jar not on classpath in tomcat6 [message #211752] |
Thu, 03 April 2008 12:19  |
Originally posted by: adam.hardy.no.spam.cyberspaceroad.spam
I have a project which uses the Tomcat Jasper code to precompile JSPs. Jasper is
currently on the classpath via the Apache Tomcat 6 plugin.
However, I run into this when using it:
java.lang.NoClassDefFoundError: org/apache/juli/logging/LogFactory
at org.apache.jasper.servlet.JspServlet.<init>(JspServlet.java:60)
and I checked what's what and my tomcat installation has tomcat-juli.jar in its
/bin directory and the jar doesn't make it into the classpath available to the
project.
It's OK running in-container, this is fine - however I would like to use tomcat
running just as a dependency of a JUnit test.
As a work-around, I copied the tomcat-juli.jar from tomcat/bin to tomcat/lib. It
seems to accept the duplication of the jar.
What about future? Is it probable that the tomcat plugin will have to
incorporate the tomcat/bin dir into the classpath?
Adam
| Re: tomcat-juli.jar not on classpath in tomcat6 [message #211781 is a reply to message #211761] |
Fri, 04 April 2008 06:03  |
Larry Isaacs on 03/04/08 17:37, wrote:
>> Jasper is currently on the classpath via the Apache Tomcat 6 plugin.
>> tomcat-juli.jar in its /bin directory and the jar doesn't make it into
>> the classpath available to the project.
>> use tomcat running just as a dependency of a JUnit test.
>> tomcat/lib. It seems to accept the duplication of the jar.
>> Thanks
>> Adam
> When using the WTP Tomcat support, tomcat-juli.jar will automatically be
> included on the "classpath" due to its presence in the Class-Path
> attribute found in the MANIFEST.MF file in Tomcat 6's bootstrap.jar. If
> you launch Tomcat in a way that doesn't honor this Class-Path attribute,
> then you would need to add it, and possibly others in that list, manually.
OK, I will follow that. Thanks alot.
Adam
FUDForum. Page generated in 0.02911 seconds
