| Tomcat Silent Deploy [message #211178] |
Thu, 27 March 2008 04:12  |
Mohsen Saboorian Messages: 19 Registered: July 2009 |
Junior Member |
I used to change my non-Java files (.jsp, .js, .css) and it was silently
deployed to tomcat working directory (when tomcat was running) without any
need to restart. But it's some time that when I change even a single .js
file, the whole application is restarted and causes problems.
What should I do to have Eclipse copy non-Java files silently to tomcat
working directory?
Mohsen.
| Re: Tomcat Silent Deploy [message #211201 is a reply to message #211178] |
Thu, 27 March 2008 16:51  |
Larry Isaacs Messages: 1261 Registered: July 2009 |
Mohsen Saboorian wrote:
> working directory?
> Mohsen.
If you are asking what triggers Tomcat to reload a web application, you
might have better luck asking on the Tomcat Users mailing list. As far
as I know, static content typically should not do so. It is also
possible that something is being published in addition to your change
that is triggering the reload. However, there isn't enough detail here
to do much speculation beyond that.
Larry
FUDForum. Page generated in 0.08534 seconds
