| Re: XML Catalog - reference to an XSD placed in a zip file [message #211059 is a reply to message #211041] |
Wed, 26 March 2008 09:51   |
--------------040006050104020307040704
Istvan,
That should be possible, but you need to use a protocol/scheme that the
JVM knows about. Some JVMs use zip: while others use jar:. I'd expect
jar:file://c:/some.zip!/thing.xsd to work on most JVMs (and for zip to
work in place of jar for some). Note some important things. The form
is jar:<absoluteURI>!/path, so no "/" after the jar:. The absolute URI
will be something like file:/... or http://... Also note the !/
separating the absolute URI from the path within the jar/zip. I'm not
sure if WTP has EMF's URI converter hooked up and therefore would
support archive: as the scheme which supports access to jars within jars
nested to any level:
<https://bugs.eclipse.org/bugs/show_bug.cgi?id=84327>
Note that org.eclipse.emf.common.archive.Hander.register() can be called
to register "archive" as a real live protocol such that new
URL("archive:...").openStream would work properly.
Istvan wrote:
> Is it possible to add a zipped XSD file to the XML catalog? Without
> unzipping, of course :). For example, the URI would be
> zip:///c:/some.zip/thing.xsd
> Istvan
<html>
<head>
http-equiv="Content-Type">
</head>
Istvan,<br>
<br>
JVM knows about.
FUDForum. Page generated in 0.01538 seconds
