Home » Eclipse Projects » Web Tools Project (WTP) » JavaScript debugging not available
JavaScript debugging not available [message #210937] Tue, 25 March 2008 14:22 Go to next message
Eclipse User
Originally posted by: jmordax.terra.es
Hi, I am using WTP 3.0M5.
I have seen JavaScript Debugger video/demo at
http://www.eclipse.org/atf/flash/index4.php but I am not able to add any
kind of breakpoint to my code. It doesn't matter if I try to add to a
*.js file or a scriptlet inside a *.html or *.jsp page.
Is there any preference I should check to enable debugging options? Is
this something that is not available in WTP 3.0M5?
Thanks in advance,
Chemi.
Re: JavaScript debugging not available [message #210958 is a reply to message #210937] Tue, 25 March 2008 14:58 Go to previous messageGo to next message
Nitin Dahyabhai is currently offline Nitin Dahyabhai
Yes, you'll need to add the ATF download from
http://www.eclipse.org/atf/ .
Nitin Dahyabhai
Eclipse WTP Source Editing
IBM Rational
Nitin Dahyabhai
Eclipse WTP, IBM
Re: JavaScript debugging not available [message #210966 is a reply to message #210958] Tue, 25 March 2008 15:43 Go to previous message
Eclipse User
>> any kind of breakpoint to my code. It doesn't matter if I try to add
>> to a *.js file or a scriptlet inside a *.html or *.jsp page.
>> Is this something that is not available in WTP 3.0M5?
> Nitin Dahyabhai
> IBM Rational
Thanks Nitin. Just let me ask something else related....
- It seems ATF 0.2.3M4 requires WTP 2.0 and i am testing WTP 3.0M5.
Although it won't be supported, is it possible to combine ATF 0.2.3M4
with WTP 3.0M5?
- Now I am little bit confuse and reading ATF and WTP project sites I
don't get a clear idea. Where is really Javascript support? Do we have
the editor in WTP but the debugger in ATF? Is there any URL where I can
read what is included in which project? Also, when trying to open a
Javascript related bug I have both options under Web Tools component:
ATF and WebTools and inside this last one I have wst.jsdt and
wst.javascript. Any tip to choose correctly?
Thanks again,
Chemi.
Previous Topic:Missing Contents of WEB-INF directory
Next Topic:trinidad-api & trinidad-impl
Current Time: Thu May 23 20:00:14 EDT 2013
Powered by FUDForum. Page generated in 0.01500 seconds
