Home » Eclipse Projects » Web Tools Project (WTP) » Eclipse can't find TLD in build path
Eclipse can't find TLD in build path [message #209483] Tue, 04 March 2008 11:34 Go to next message
David M. Karr is currently offline David M. Karr
I'm assembling a dynamic web app from some sample JSP and some framework
jars. I copied the sample JSP into WebContent, and I copied the framework
jars into WebContent/WEB-INF/lib. However, inside the JSP, it complains
that it can't find the tld for the given taglib URI. I verified that the
TLD contained in the jar file in WEB-INF/lib has a URI that matches the
URI from the taglib directive. What else could I be doing wrong?
Re: Eclipse can't find TLD in build path [message #209551 is a reply to message #209483] Tue, 04 March 2008 15:23 Go to previous message
Nitin Dahyabhai is currently offline Nitin Dahyabhai
> framework jars into WebContent/WEB-INF/lib. However, inside the JSP, it
> complains that it can't find the tld for the given taglib URI. I
> verified that the TLD contained in the jar file in WEB-INF/lib has a URI
> that matches the URI from the taglib directive. What else could I be
> doing wrong?
You've probably just run into a problem with the order in which you
did things. Revalidating the JSP should clear the validation
error--the first time it was validated the jars weren't in place.
Nitin Dahyabhai
Eclipse WTP Source Editing
IBM Rational
Nitin Dahyabhai
Eclipse WTP, IBM
Previous Topic:Tomcat v5.5 Server at localhost failed to start
Next Topic:Connecting to a Remote Server
Current Time: Sat May 25 07:52:19 EDT 2013
Powered by FUDForum. Page generated in 0.01506 seconds
