Home » Eclipse Projects » Web Tools Project (WTP) » Persistent incorrect password file generatation
| Persistent incorrect password file generatation [message #208641] |
Fri, 15 February 2008 10:59  |
Originally posted by: tim.visher.gmail.com
Hello Everyone,
I tried to use the search tools as I'm sure that this question has been
asked and answered before but I couldn't come up with anything so I was
probably not using them correctly. Forgive me. :)
Anyway, I have a strange thing happening to me. I have a copy of Sun
Java Application Server PE 9 on my machine and I have eclipse connected to
it through the GlassFish V2 Java EE 5 connector. When I created the
server, I incorrectly specified the admin password (it was just left at
the default). In an attempt to correct that I have done the following:
Server View -> Open Server -> Edit Admin Password:
Doesn't work, persists till I close the server and then changes back to
the original password.
Edit the generated passwd file directly:
Obviously this doesn't work because the file gets cleanly generated every
time.
Edit sunappsrv-ant.xml directly and hardcode the correct password into the
file:
Doesn't work, I suppose because this file gets generated automatically?
Anyway, my real question lies in this, how could I recover from a password
change on the admin user? Why wouldn't the changes I made to the Server
from within eclipse drop through to the config file?
At this point I've solved the problem by recreating the connection to the
server through Server -> New and correctly specifying the password.
However, it's entirely conceivable that the admin would want to change the
password so I figure Eclipse has to be able to do this in some simple way.
Thanks for any information!
Timmy V.
| Re: Persistent incorrect password file generatation [message #209186 is a reply to message #208641] |
Thu, 28 February 2008 12:44   |
On 2008-02-15 10:59:51 -0500, tim.visher@gmail.com (Tim Visher) said:
> Hello Everyone,
> to it through the GlassFish V2 Java EE 5 connector. When I created the
> Obviously this doesn't work because the file gets cleanly generated every time.
> the file:
> password change on the admin user? Why wouldn't the changes I made to
> the Server from within eclipse drop through to the config file?
> the server through Server -> New and correctly specifying the password.
> the password so I figure Eclipse has to be able to do this in some
> simple way.
> Timmy V.
Just wondering if there was any other news here? It seems like a
fairly reasonable question, if a little infantile. Any help would be
greatly appreciated.
| Re: Persistent incorrect password file generatation [message #209193 is a reply to message #209186] |
Thu, 28 February 2008 13:31   |
Larry Isaacs Messages: 1261 Registered: July 2009 |
>> Hello Everyone,
>> been asked and answered before but I couldn't come up with anything so
>> I was probably not using them correctly. Forgive me. :)
>> connected to it through the GlassFish V2 Java EE 5 connector. When I
>> created the server, I incorrectly specified the admin password (it was
>> just left at the default). In an attempt to correct that I have done
>> the following:
>> to the original password.
>> every time.
>> the file:
>> password. However, it's entirely conceivable that the admin would
>> want to change the password so I figure Eclipse has to be able to do
>> Timmy V.
> Just wondering if there was any other news here? It seems like a fairly
> reasonable question, if a little infantile. Any help would be greatly
> appreciated.
You might have better luck asking on a newsgroup related to the
GlassFish plug-ins. The GlassFish plug-ins are built on top of, but
aren't actually a part of WTP. I don't think your issue is something we
can address in WTP.
Larry
| Re: Persistent incorrect password file generatation [message #209217 is a reply to message #209193] |
Thu, 28 February 2008 14:25   |
On 2008-02-28 13:31:03 -0500, Larry Isaacs <Larry.Isaacs@sas.com> said:
>>> Hello Everyone,
>>> the file:
>>> simple way.
>>> Timmy V.
> we can address in WTP.
> Cheers,
> Larry
Ah, that would explain a lot. Thanks for the advice.
| Re: Persistent incorrect password file generatation [message #209231 is a reply to message #209217] |
Thu, 28 February 2008 14:31   |
>>>> Hello Everyone,
>>>> the file:
>>>> simple way.
>>>> Timmy V.
>> Cheers,
>> Larry
BTW, did you have a recommendation on what newsgroup to move to. I did
a very quick search and couldn't find anything pertinent. Just thought
I'd ask someone who might know before I wasted too much time crawing
around in the dark.
Thanks in advance!
Timmy V.
| Re: Persistent incorrect password file generatation [message #209237 is a reply to message #209231] |
Thu, 28 February 2008 16:03  |
>>>>> Hello Everyone,
>>>>> so I was probably not using them correctly. Forgive me. :)
>>>>> Sun Java Application Server PE 9 on my machine and I have eclipse
>>>>> I created the server, I incorrectly specified the admin password
>>>>> (it was just left at the default). In an attempt to correct that I
>>>>> back to the original password.
>>>>> every time.
>>>>> into the file:
>>>>> automatically?
>>>>> to the Server from within eclipse drop through to the config file?
>>>>> to the server through Server -> New and correctly specifying the
>>>>> Timmy V.
>>>> be greatly appreciated.
>>> Cheers,
>>> Larry
> around in the dark.
> Thanks in advance!
> Timmy V.
Googling turned up "https://glassfishplugins.dev.java.net/". You might
try one of the mailing lists off the "Mailing lists" link on that page.
Unfortunately, a quick check of various archives doesn't show a lot of
activity. I don't know if there is anything better.
Larry
Current Time: Sat May 25 11:35:27 EDT 2013
Powered by FUDForum. Page generated in 0.01692 seconds
