| JSP validation foobar'd by my syntax [message #207677] |
Tue, 29 January 2008 11:43  |
Originally posted by: adam.hardy.no.spam.cyberspaceroad.spam
Eclipse's latest JSP validator with WTP 2.0.1.v20070911 is great and has dealt
with most of the stuff I throw at it.
I finally put a spanner in the works with this piece of JSP and the JSP
validator doesn't like it at all. The minimum test case I could reduce it to is
the following:
<%@ taglib prefix="a" uri="http://www.permacode.org/taglib/atomic-1.0" %>
<input type="submit" id="speciesSubmit"
value="${a:translate('general.submit.button')}"
name="method:save" />
<input type="reset" value="${a:translate('general.reset.button')}"/>
<input type="submit" name="method:cancel"
value="${a:translate('general.cancel.button')}"/>
The errors don't make sense:
Syntax error on token "throws", delete this token
or
Syntax error on token ",", . expected
or a combination of up to 6!
Is this a bug or is any of the syntax I'm using just not accepted by the validator?
Adam
| Re: JSP validation foobar'd by my syntax [message #207746 is a reply to message #207731] |
Tue, 29 January 2008 14:06   |
Nitin Dahyabhai on 29/01/08 18:34, wrote:
>> has dealt with most of the stuff I throw at it.
>> JSP validator doesn't like it at all. The minimum test case I could
>> reduce it to is the following:
>> or
>> the validator?
> It doesn't cause any validation messages that I can see, but I do not
> have the tag library you're using. Does it vary with the amount of EL
> you're using?
Maybe my validation error is because of my taglibrary - I replaced the function
calls with JSTL standard fn:length() and the errors vanished.
I was unable to find anything more than rudimentary documentation about writing
functions in taglibraries, so I don't know what goes on to validate or process
them.
This ${a:translate()} must require some more config than I have given it. I
simply wrote the class and included it in my TLD like this:
<function>
<name>translate</name>
<function-class>org.permacode.atomic.JspFunctionLibrary</function-class >
<function-signature>
java.lang.String translate(java.lang.String)
</function-signature>
</function>
What more is required? Is there a URL to documentation on this that provides
more than the JEE 1.5 tutorial?
Adam
| Re: JSP validation foobar'd by my syntax [message #208457 is a reply to message #207746] |
Mon, 11 February 2008 11:21  |
>>> or
>>> the validator?
>> you're using?
> function calls with JSTL standard fn:length() and the errors vanished.
> writing functions in taglibraries, so I don't know what goes on to
> validate or process them.
> it. I simply wrote the class and included it in my TLD like this:
> <function>
> </function>
> provides more than the JEE 1.5 tutorial?
I'm hoping that someone will be able to tell me what the JSP validator is
inspecting behind the scenes which causes it to throw a validation error with my
taglib.
Thanks in advance,
Adam
FUDForum. Page generated in 0.01698 seconds
