Home » Eclipse Projects » Web Tools Project (WTP) » JBoss server not getting created in WTP 2
JBoss server not getting created in WTP 2 [message #206354] Thu, 03 January 2008 02:32 Go to next message
Eclipse User
Originally posted by: inderjeet.singh.siemens.com
I have recently installed Eclipse WTP 2.0 on my machine. I also have JBoss
4.0.4 GA application server. I have Sun jdk1.5.0_14 on my machine.
I have copied the default server instance of JBoss and created a new
server named "test" in Jboss. I have also changed the port number to 1010.
Now when I try to create this new server instance "test" of JBoss on
eclipse, it is not creating the server instance. I checked in eclipse .log
file, it is throwing the following exception.
!ENTRY org.eclipse.ui 4 0 2008-01-03 12:55:27.655
!MESSAGE Unhandled event loop exception
!STACK 0
java.lang.IllegalArgumentException: Index out of bounds
But when I try to create the server instance of the "default" Jboss server
in eclipse, it is getting created easily.
Any pointers in this regard please...
Thanks and regards
Inder Jeet Singh
Re: JBoss server not getting created in WTP 2 [message #206386 is a reply to message #206354] Fri, 04 January 2008 06:31 Go to previous messageGo to next message
Eclipse User
I tried the same thing by changeing the version of the JBoss server to
4.2.0 HA but still it does not work.
Any pointers please????
Thanks & Regards
Inder Jeet Singh
Re: JBoss server not getting created in WTP 2 [message #206394 is a reply to message #206386] Fri, 04 January 2008 09:12 Go to previous message
Eclipse User
Originally posted by: wknauf_NO_._INSIDE_hg-online.de
Sounds like a bug. You should report it to bugzilla (https://bugs.eclipse.org/bugs/)
Best regards
Wolfgang
Inder Jeet Singh schrieb:
> Thanks & Regards
> Inder Jeet Singh
Previous Topic:HTML/jsp design with WTP
Next Topic:How Can I get the specified source code?
Current Time: Fri May 24 10:52:58 EDT 2013
Powered by FUDForum. Page generated in 0.01660 seconds
