Home » Eclipse Projects » Web Tools Project (WTP) » Utility Module
Utility Module [message #205819] Fri, 14 December 2007 04:35 Go to next message
Eclipse User
Originally posted by: michael_post.web.de
Hello list-dwellers,
i can not find any answer with google so i try it here.
I have an eclipse 3.2 and i can not find anywhere the facet "utility
module" to set the reference of my web project to the other web project so
i can deploy it successfully.
Where can i download this facet and how i can implement it in this version
of eclipse. I know that this is not the current version, but i can not
update it, because it is the Workshop of BEA Systems and i need the other
functions.
Do you have any documentation or tutorials for the implementation?
Thanks a lot,
Michael
Re: Utility Module [message #205827 is a reply to message #205819] Fri, 14 December 2007 04:54 Go to previous messageGo to next message
Eclipse User
sorry. It is not an eclipse 3.2 as i thought. It's an eclipse 3.1. :-(
Any ideas?
Thx
Michael
Re: Utility Module [message #205884 is a reply to message #205819] Fri, 14 December 2007 15:13 Go to previous messageGo to next message
Angel Vera is currently offline Angel Vera
Member
Hi Michael,
You don't need to download a facet. What you need to do is to go into your
Web project properties, and in the J2EE Module dependencies page, check
mark the java project that you want to setup as your utility project.
Hope it helps.
Angel Vera
WTP Server Tools Developer
Re: Utility Module [message #205939 is a reply to message #205884] Mon, 17 December 2007 10:19 Go to previous messageGo to next message
Eclipse User
thanks for your reply. But exactly this is my problem.
I can not check anything like this.
Michael
Re: Utility Module [message #205976 is a reply to message #205939] Mon, 17 December 2007 12:24 Go to previous messageGo to next message
Rob Frost is currently offline Rob Frost
Member
Hi Michael,
From your initial post, it sounds like you are attempting to add the
jst.utility facet to an existing dynamic web project (i.e. a project that
already has the jst.web facet) and then create a dependency between these
two projects.
The jst.utility and jst.web facets are mutually exclusive and you are not
allowed to create a module dependency from one web project to another web
project.
Please see bugzilla https://bugs.eclipse.org/bugs/show_bug.cgi?id=115990 for
the web-to-web dependency issue (I know this issue has been discussed in
some detail in other threads but cannot locate them at present).
Hope this helps,
-Rob
"Michael Post" <michael_post@web.de> wrote in message
news:f93685a966bb292e733d1ebb638ba430$1@www.eclipse.org...
> Hello,
> Michael
Re: Utility Module [message #206053 is a reply to message #205976] Wed, 19 December 2007 14:26 Go to previous message
Eclipse User
thanks for you help.
My failure was, that i have to create this module as an Utility project
and not as i did it as dynamic web project.
Now i fixed it.
Thanks for your help,
Michael
Previous Topic:specifying only some project src dirs to deploy to tomcat
Next Topic:Programmatically adding imports to jsp file
Current Time: Sat May 18 07:26:54 EDT 2013
Powered by FUDForum. Page generated in 0.02013 seconds
