| Re: Jsp: Compile to appropriate TOMCAT_HOME dir? [message #205427] |
Thu, 06 December 2007 13:25  |
Abel wrote:
> Hi all,
> In my new Eclipse installation I plan to do some work on Jsp's. The Jsp
> output eventually should be placed in the
> TOMCAT_HOME/webapps/examples/jsp directory. To that I'm wondering,
> should I try to instruct Eclipse to "build" the jsp to that directory
> (and how?), or should I use Eclipse as the debugging environment, and
> when everything is finished, copy the WAR to Tomcat?
Probably best to ask this on the eclipse.webtools newsgroup, which I've
copied to this response.
Eric
| Re: Jsp: Compile to appropriate TOMCAT_HOME dir? [message #205474 is a reply to message #205452] |
Fri, 07 December 2007 03:18  |
Originally posted by: MacAdam.eden.invalid
Larry Isaacs wrote:
> Eric Rizzo wrote:
>> Abel wrote:
>>> Hi all,
>>> Jsp output eventually should be placed in the
>> I've copied to this response.
>> Eric
> Is there some reason you are looking to deploy the JSPs to Tomcat's
> "examples" webapp as opposed to working on them in your own webapp and
> deploying that webapp? The later approach is the one supported by WTP.
> Cheers,
> Larry
Hi Larry and Eric,
Thanks for moving to the correct newsgroup. As I said, I'm new to
Eclipse and JSP's. In the past I had experience with mySAP Enterprise
Portals. JSP's is new to me (so therefore the "examples" webapp), so I'm
still getting my bearings. I don't think I have my Eclipse configured
correctly. But experience will show me the way.
Abel
FUDForum. Page generated in 0.01609 seconds
