| Line delimiters [message #204741] |
Tue, 20 November 2007 03:50  |
Originally posted by: jan.bares.ips-ag.net
can I configure Eclipse line delimiters for jsp files to use the same
delimiters as are already present in edited file? There are no such
settings in Web and XML/JSP files, line delimiters. When I open jsp file
with UNIX line delimiters, I want to use UNIX line delimiters for new
lines and vice versa no matter the platform Eclipse is running on. This
feature works fine for *.java files, why is this changed in wtp?
Thanks Jan
| Re: Line delimiters [message #204792 is a reply to message #204741] |
Wed, 21 November 2007 08:24   |
Originally posted by: ns_dkerber.ns_WarrenRogersAssociates.com
In article <089bf703f60427cee8c3c970c102fccf$1@www.eclipse.org>,
jan.bares@ips-ag.net says...
There are lots of things in the UI that don't work the same for .java
files as they do .jsp files.
Remove the ns_ from if replying by e-mail (but keep posts in the
newsgroups if possible).
| Re: Line delimiters [message #204799 is a reply to message #204792] |
Wed, 21 November 2007 09:07  |
--------------060106040902080407030602
I'm sure that's true, but I think the desire to preserve the line feed
conventions of an existing file is a reasonable one and this is
supported by most of the rest of Eclipse. If that's not working
properly in this context, I'd open a bugzilla about it. I know for
EMF's generator we added support so that regenerating a file matches the
conventions already used by that file rather that using some global
preference or the OS's default.
<html>
<head>
http-equiv="Content-Type">
</head>
FUDForum. Page generated in 0.01636 seconds
