Home » Eclipse Projects » Web Tools Project (WTP) » Re: Mylyn 2.1 is now available
Re: Mylyn 2.1 is now available [message #202433] Tue, 16 October 2007 23:44 Go to next message
David Carver is currently offline David Carver
Mik Kersten wrote:
> Werner, I assume that you are using the ../e3.4 update sites.
> http://www.eclipse.org/mylyn/downloads/
> Please do file a bug since this is odd (Mylyn has no dependencies on
> WTP) and we should investigate.
Something similar. The Project Explorer context focused UI also seems
to stop working with the WTP J2EE plugins installed. It works fine
with just the WST plugins only installed. I noticed this after
installing 2.1 of Mylyn and 2.0.1 of WTP.
> Mik
> Werner Keil wrote:
>> It seems, both the official 2.1 release and the Weekly Build (already
>> labels itself 2.2.x) don't work with 3.4M2 and WTP 3 correctly?!
>> Nothing can be installed and the errors shown by Update Manager don't
>> seem to make much sense:
>> The current configuration contains errors and this operation can have
>> unpredictable results.
>> WST Web Services UI (2.0.1.v200710021354-792EGwAufYO8FqYlmS_5Ff4sbiKz)
>> requires plug-in "org.eclipse.gef (3.2.0)", or compatible.
>> WTP Web Page Editor (1.1.0.v200709202235-3-29oA55P855A) requires
>> Java Persistence API Tools (1.1.0.v200709170000-772AgCYQCCz-D_LoCCEH)
>> requires feature "org.eclipse.datatools.connectivity.feature".
>> WST Common UI (2.1.0.v200709192200-7C6EIaE9RvTVninpsnWz0WgQZgle)
>> requires plug-in "org.eclipse.draw2d (3.2.0)", or compatible.
>> Eclipse XML Editors and Tools
>> (2.1.0.v200709192200-7A3EIPCnbckz0itrBsMmAKQjdclf) requires plug-in
>> At least the WTP Web Page Editor does however work correctly.
>> Installing both Mylyn 2.x releases over a 'naked' 3.4M2 works.
>> One can even copy such updates manually over the WTP 3 installation, but
>> while Mylyn works there too as far as I can see, adding further
>> components like 'Exras' fails with the same error (pointing to Web Page
>> Editor)
>> I might be able to raise this Bug (not sure, which part is the actual
>> reason for it, but it only manifests itself when trying to install Mylyn
>> so far) using a working Mylyn installation somewhere, too...
>> Thanks and Regards,
>> Werner
>> Mik Kersten wrote:
>>> We are pleased to announce that Mylyn 2.1 is now available and supports
>>> Eclipse 3.3 and 3.4M2.
>>> http://eclipse.org/mylyn/new/
>>> http://eclipse.org/mylyn/downloads/
>>> This release of Mylyn is also included with three of the Eclipse Europa
>>> Fall Update bundles released today:
>>> http://eclipse.org/downloads/
>>> The Mylyn Team
Re: Mylyn 2.1 is now available [message #203593 is a reply to message #202433] Fri, 02 November 2007 22:33 Go to previous message
Eclipse User
Originally posted by: beatmik.acm.org
I couldn't reproduce this. If it is still happening please file a Mylyn
bug so that we can diagnose further.
Mik
Previous Topic:Is there an unrestricted API similar to IModelManager.getModelForRead(IFile)?
Next Topic:WTP, JBOSS 4.2 and EJB 2
Current Time: Thu May 23 18:43:35 EDT 2013
Powered by FUDForum. Page generated in 0.01432 seconds
