| WTP 2.0.1 - Perm gen space errors [message #202270] |
Mon, 15 October 2007 11:44  |
mark streit Messages: 11 Registered: July 2009 |
Junior Member |
I know this is not the first post of this kind since the WTP 2.0.1 release
but I have 2 Eclipse installs on my machine - both are the "all-in-one"
packages for WTP 2.X - the one for WTP 2.0.0 appears to run fine. The one
for the most recent WTP 2.0.1 release also runs ok but then at some point, I
start getting this garbage:
!ENTRY org.eclipse.ui.workbench 4 0 2007-10-15 11:29:30.765
!MESSAGE Widget disposed too early!
!SESSION Mon Oct 15 11:29:42 EDT
2007 ------------------------------------------
!ENTRY org.eclipse.equinox.launcher 4 0 2007-10-15 11:29:42.421
!MESSAGE Exception launching the Eclipse Platform:
!STACK
java.lang.OutOfMemoryError: PermGen space
It's odd because I only see this repeatedly w/ the newer release and the
eclipse.ini file contents for each installation look exactly the same:
-showsplash
org.eclipse.platform
--launcher.XXMaxPermSize
256m
-vmargs
-Xms40m
-Xmx256m
-showsplash
256m
-vmargs
-Xms40m
-Xmx256m
Any ideas as to why the behavior between the 2 releases would be the same
re: memory. If the .ini file for the newer release required different
values, were they not packaged w/ those changes?
| Re: WTP 2.0.1 - Perm gen space errors [message #202285 is a reply to message #202270] |
Mon, 15 October 2007 12:02   |
--------------080006090407050604070502
Mark,
Lots of people are being affected by this bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=203325
I'm hoping that a decision will be made to spin an Eclipse 3.3.1a build
to fix this. I believe the above bug report describes a simple
workaround...
> !STACK
> -showsplash
> 256m
> -vmargs
> -Xms40m
> -Xmx256m
> -showsplash
> 256m
> -vmargs
> -Xms40m
> -Xmx256m
> Thanks
<html>
<head>
</head>
Mark,<br>
<br>
Lots of people are being affected by this bug:<br>
<blockquote><a
href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=203325">https://bugs.eclipse.org/bugs/show_bug.cgi?id=203325</a>
<br>
</blockquote>
workaround...<br>
<br>
<br>
mark streit wrote:
<blockquote cite="mid:ff01ol$i6b$1@build.eclipse.org" type="cite">
<pre wrap="">I know this is not the first post of this kind since the WTP 2.0.1 release
!STACK
-showsplash
256m
-vmargs
-Xms40m
-Xmx256m
-showsplash
256m
-vmargs
-Xms40m
-Xmx256m
</pre>
</blockquote>
<br>
</body>
</html>
--------------080006090407050604070502--
| Re: WTP 2.0.1 - Perm gen space errors [message #203118 is a reply to message #202270] |
Fri, 26 October 2007 04:07  |
Originally posted by: baldervancamp.telenet.be
QuickFix: add next line to your eclipse.ini after other vmargs.
-XX:MaxPermSize=256m
Thanks to the bug report !
> !STACK
> -showsplash
> 256m
> -vmargs
> -Xms40m
> -Xmx256m
> -showsplash
> 256m
> -vmargs
> -Xms40m
> -Xmx256m
> Thanks
FUDForum. Page generated in 0.07757 seconds
