Home » Eclipse Projects » Web Tools Project (WTP) » Design view of WSDL doesn't link to soap fault type
Design view of WSDL doesn't link to soap fault type [message #202569] Wed, 17 October 2007 16:39 Go to next message
David M. Karr is currently offline David M. Karr
Using SDK 3.3.1 on WinXP.
I was just browsing through the graphical view capabilities of a WSDL.
I noticed that in the view of a portType, the "input" and "output" pieces
look fine, including the ability to navigate to the element descriptions,
but when I have a fault piece, the arrow at the end is a "broken" arrow,
so it can't navigate to the fault element. I've validated the WSDL, and
it appears to be fine. If I open up the referenced schema, it also looks
fine, and validates.
Is this expected, or is there something wrong with the WSDL and/or schema
that I'm not noticing?
Re: Design view of WSDL doesn't link to soap fault type [message #202577 is a reply to message #202569] Wed, 17 October 2007 18:13 Go to previous messageGo to next message
Hmm. After I exited Eclipse and came back in, this is now fixed. That
doesn't make much sense.
Re: Design view of WSDL doesn't link to soap fault type [message #202585 is a reply to message #202577] Wed, 17 October 2007 18:40 Go to previous message
Eclipse User
Originally posted by: valentinbaciu.hotmail.com
David, if you can reproduce the issue consistently, please open a bug
against wst.wsdl and describe the scenario (version, steps, etc).
"David Karr" <david.karr@wamu.net> wrote in message
news:54035423ca9bea9ef1425e680ee722ee$1@www.eclipse.org...
Previous Topic:Connection Pooling and reusing connections on republish of Tomcat webapp within IDE
Next Topic:How to: Convert a org.apache.xerces.dom Node to org.eclipse.wst.html.core.internal.document Node
Current Time: Thu May 23 02:44:07 EDT 2013
Powered by FUDForum. Page generated in 0.01652 seconds
