Home » Eclipse Projects » Web Tools Project (WTP) » dependant project's libs
dependant project's libs [message #201482] Mon, 08 October 2007 06:34 Go to next message
Zohar Amir is currently offline Zohar Amir
I've asked about this before, but I hope there's been some progress since...
I have a Web project which depends on another java project. The java project
uses some jar file (they are marked to be exported in that project's build
path's export tab). When I export my web project to a WAR file those jar
files are not included in that WAR file.
Any way of making them being included?
Re: dependant project's libs [message #201498 is a reply to message #201482] Mon, 08 October 2007 10:45 Go to previous messageGo to next message
Larry Isaacs is currently offline Larry Isaacs
In WTP 2.0, you should see a warning in the Problems view like the
following:
Classpath entry <your exported jar> will not be exported or published.
Runtime ClassNotFoundExceptions may result.
The only UI way to have the jar included is to use the Quick Fix on this
problem item. If you have done this and the jar is still not being
included, it would be a bug.
Larry
zohar wrote:
> since...
> project uses some jar file (they are marked to be exported in that
> project's build path's export tab). When I export my web project to a
> WAR file those jar files are not included in that WAR file.
Re: dependant project's libs [message #201506 is a reply to message #201498] Mon, 08 October 2007 15:29 Go to previous messageGo to next message
Thanks.
One thing though - any reason why I cannot select multiple warnings and fix
them all at once?
BTW: if there's ever a contest for the most helpful person on this (and
other) newsgroup - you have my vote.
"Larry Isaacs" <Larry.Isaacs@sas.com> wrote in message
news:fedfph$5vs$1@build.eclipse.org...
> following:
> Cheers,
> Larry
> zohar wrote:
>> since...
>> project's build path's export tab). When I export my web project to a WAR
Re: dependant project's libs [message #201514 is a reply to message #201498] Mon, 08 October 2007 15:38 Go to previous messageGo to next message
What does this quick fix do?
> following:
> Cheers,
> Larry
> zohar wrote:
>> since...
Re: dependant project's libs [message #201553 is a reply to message #201514] Tue, 09 October 2007 08:19 Go to previous messageGo to next message
It adds an attribute to the classpath entry for the exported jar in the
..classpath file of the utility project. Once the attribute is there,
you can see evidence of it under the jar in the Libraries tab of the
Java Build Path properties. You can select the attribute and remove it
if necessary using that project properties page.
Larry
>> following:
>> Cheers,
>> Larry
>> zohar wrote:
>>> Hi,
>>> since...
Re: dependant project's libs [message #201561 is a reply to message #201506] Tue, 09 October 2007 08:20 Go to previous messageGo to next message
I'm not sure if the "Quick Fix" API supports handling more than one
problem at a time. I would guess that the "Quick Fix" approach wasn't
chosen because of its desirability, but simply because it didn't require
any new API to be added. I'm not sure what is planned for the future
with respect to improved UI for this feature, but I would also guess
that will likely require support to be added outside of WTP, probably in
JDT.
Larry
zohar wrote:
> Thanks.
> them all at once?
>> following:
>> Cheers,
>> Larry
>> zohar wrote:
>>> Hi,
>>> since...
Re: dependant project's libs [message #201595 is a reply to message #201561] Tue, 09 October 2007 10:30 Go to previous messageGo to next message
after I did the quick fix I got something like for each jar:
Invalid classpath publish/export dependency
/Project/lib/commons-codec-1.3.jar. Dependencies for non-web projects must
be exported.
What's that?
news:fefrln$v03$1@build.eclipse.org...
> any new API to be added. I'm not sure what is planned for the future with
> respect to improved UI for this feature, but I would also guess that will
> likely require support to be added outside of WTP, probably in JDT.
> Cheers,
> Larry
> zohar wrote:
>> Thanks.
>> fix them all at once?
>>> following:
>>> Cheers,
>>> Larry
>>> zohar wrote:
>>>> Hi,
>>>> since...
Re: dependant project's libs [message #201620 is a reply to message #201595] Tue, 09 October 2007 11:29 Go to previous messageGo to next message
It means you haven't exported that jar in the utility project. You will
need to export it to fix the error.
Larry
> be exported.
> What's that?
>> Cheers,
>> Larry
>> zohar wrote:
>>> Thanks.
>>>> following:
>>>> Cheers,
>>>> Larry
>>>> zohar wrote:
>>>>> Hi,
>>>>> since...
Re: dependant project's libs [message #201629 is a reply to message #201620] Tue, 09 October 2007 11:52 Go to previous messageGo to next message
In 'Java Build Path' -> 'Order and Export' it is checked...
Is that the right place?
news:feg6ov$st3$1@build.eclipse.org...
> Larry
>> must be exported.
>> What's that?
>>> JDT.
>>> Cheers,
>>> Larry
>>> zohar wrote:
>>>> Thanks.
>>>>> following:
>>>>> this problem item. If you have done this and the jar is still not
>>>>> being included, it would be a bug.
>>>>> Cheers,
>>>>> Larry
>>>>> zohar wrote:
>>>>>> Hi,
>>>>>> since...
Re: dependant project's libs [message #201637 is a reply to message #201620] Tue, 09 October 2007 11:53 Go to previous messageGo to next message
I just run the 'Validate' on those projects and it got OK...
> Larry
>> must be exported.
>> What's that?
>>> JDT.
>>> Cheers,
>>> Larry
>>> zohar wrote:
>>>> Thanks.
>>>>> following:
>>>>> Cheers,
>>>>> Larry
>>>>> zohar wrote:
>>>>>> Hi,
>>>>>> since...
Re: dependant project's libs [message #201645 is a reply to message #201629] Tue, 09 October 2007 12:24 Go to previous messageGo to next message
Yes. That worked for me in a simple test case. Assuming the
/lib/commons-codec-1.3.jar in the "Project" project is exported, it may
be that something didn't cause the problem item to disappear when it
should. You might try un-exporting commons-codec-1.3.jar, save,
re-export, and save to give it another kick to try to get the problem
item to disappear.
Larry
>> Larry
>>> must be exported.
>>> What's that?
>>>> JDT.
>>>> Cheers,
>>>> Larry
>>>> zohar wrote:
>>>>> Thanks.
>>>>>> following:
>>>>>> Cheers,
>>>>>> Larry
>>>>>> zohar wrote:
>>>>>>> Hi,
>>>>>>> since...
Re: dependant project's libs [message #208907 is a reply to message #201645] Thu, 21 February 2008 09:47 Go to previous messageGo to next message
Wolfgang Röckelein is currently offline Wolfgang Röckelein
>>> will need to export it to fix the error.
Why is it necessary to export the jar?
For applications Eclipse makes a IMHO correct distinctions:
jars which are not exported are not visible e.g. for code-assist but are included at runtime.
Also tools like the FatJar include the non-exported jars.
How can I accomplish this (jar is included in the WEB-INF/lib for tun-time but not visible at design time? This is helpful eg for driver jars which are dynamically loaded. I do not want the driver
classes to be visible to the programmers as to not accidentally introduce dependencies on them them but they are obviously needed at runtime.
Wolfgang
Re: dependant project's libs [message #208949 is a reply to message #208907] Fri, 22 February 2008 09:34 Go to previous messageGo to next message
Wolfgang Röckelein wrote:
> jars which are dynamically loaded. I do not want the driver classes to
> Wolfgang
The issue relates to the difference between Java applications and Java
EE applications. By this I mean that Java applications typically have a
single classloader containing all the application jars and classes. For
Java EE applications, the Java EE application server typically provides
a classloader hierarchy including server supplied classloaders and a
classloader for the Java EE application(s). For Java EE applications in
Eclipse, the choice of exporting or not exporting is used to distinguish
between jars that belong in the Java EE application's classloader and
jars that will be available in the server supplied classloaders.
I'm not aware of a standard way to include a jar in WEB-INF/lib and not
have it visible at build/design time. Beyond using a custom Ant task to
build a war with extra "non-design time" jars included, I'm not sure
what other approaches might be available.
Larry
Re: dependant project's libs [message #208955 is a reply to message #208907] Fri, 22 February 2008 10:12 Go to previous messageGo to next message
Rob Frost is currently offline Rob Frost
Member
The requirement to export cp entries in dependent projects that are marked
for publish/export was removed in 3.0 M4 and 2.0.2 (the error is replaced
with a warning), see https://bugs.eclipse.org/bugs/show_bug.cgi?id=198338
-Rob
"Wolfgang R
Re: dependant project's libs [message #208971 is a reply to message #208955] Fri, 22 February 2008 13:58 Go to previous messageGo to next message
Yes, but the jars are not included in the WEB-INF/lib directory for tun-time availability.
The post news://news.eclipse.org:119/fpmmhf$7d6$1@build.eclipse.org from Larry made this clear,
however I am not wholly convinced that it is wise to have two different meanings
- J2EE: if not exported, jar is not in the war and not available for a run on server from eclipse
- Java: if not exported, jar is available for eg application run from eclipse
for the same setting (export jar mark), esp when it comes to Utility Projects that can be used in both settings
(or rather not really used in both settings because of this issue...
BTW, Larry: When everything is controlled by the export mark, why is then the additional marker set with the quick fix necessary?
Wolfgang
Re: dependant project's libs [message #208987 is a reply to message #208971] Fri, 22 February 2008 15:44 Go to previous messageGo to next message
>> marked for publish/export was removed in 3.0 M4 and 2.0.2 (the error
>> is replaced with a warning), see
> meanings
> eclipse
> Wolfgang
Rob is saying that I am wrong for WTP 2.0.2 and WTP 3.0 M4 and later.
If you don't export, you still get the jar in WEB-INF/lib but you will
have to live with a warning in the Problems view for this use case. I
think that is what Bug 198338 was about.
Larry
Re: dependant project's libs [message #208996 is a reply to message #208971] Fri, 22 February 2008 15:46 Go to previous message
Member
hi Wolfgang,
The JARs represented by those classpath entries certainly should be added to
the WEB-INF/lib directory of the referencing dynamic web project when it is
exported as a WAR or published despite not being exported on the Java build
path (they do need the "publish/export" attribute; I just verified this
behavior using WTP 3.0 and Tomcat 6.0).
If you are not seeing them in WEB-INF/lib it is a bug so please open a
bugzilla with appropriate repro steps.
FYI: the export check is performed for the validator; actual contribution
to the published/exported module structure is governed by the dependency cp
entry attribute (see
http://wiki.eclipse.org/ClasspathEntriesPublishExportSupport for full
details on this functionality).
Larry: if you've encountered issues with this yourself (or belief I should
revert back to the old behavior of enforcing the export with an error), let
me know.
Hope this helps,
Rob
"Wolfgang R
Previous Topic:Replacing org.eclipse.jst.servlet.ui.project.facet.WebFacetInstallPage
Next Topic:Content assist on own facet
Current Time: Sat May 25 01:58:40 EDT 2013
Powered by FUDForum. Page generated in 0.02169 seconds
