Home » Archived » IAM (Eclipse Integration for Apache Maven) » IAM maven builder not copying resources?
IAM maven builder not copying resources? [message #20033] Thu, 28 May 2009 03:46 Go to next message
BenH is currently offline BenH
Member
I just cleaned out my target/ folder and then did a Project > Clean.
target/classes and target/test-classes were recompiled, but resources
files (applicationContext.xml) seemed not to be copied over into
target/WEB-INF
So my unit tests failed from Eclipse JUnit runner, until I did a "mvn
install" from command line.
Known issue? Intended behavior?
-Ben
Re: IAM maven builder not copying resources? [message #20072 is a reply to message #20033] Thu, 28 May 2009 17:05 Go to previous message
Carlos Sanchez is currently offline Carlos Sanchez
resources files are copied by default to target/classes and
target/test-classes, they are no copied to target/WEB-INF
if your project is a war and you expect them to be in
target/projectname/WEB-INF that happens during packaging phase, and you
shouldn't rely on them being there in your test files, it wont work in
IAM nor in Maven command line
> target/WEB-INF
> -Ben
Re: IAM maven builder not copying resources? [message #569645 is a reply to message #20033] Thu, 28 May 2009 17:05 Go to previous message
> target/WEB-INF
> -Ben
Previous Topic:IAM maven builder not copying resources?
Next Topic:how do you pass properties to the build configuration
Current Time: Thu May 23 19:03:53 EDT 2013
Powered by FUDForum. Page generated in 0.02369 seconds
