| Compiler error in org.eclipse.swt.nebula.examples [message #19879] |
Wed, 06 December 2006 11:21  |
Matthew Hall Messages: 368 Registered: July 2009 |
Hello everyone,
I have checked out the nebula plugins from CVS (examples, nebface,
snippets, tests, widgets) and the examples plugin is showing several
compiler errors in PGroupExampleTab:
Severity and Description Path Resource Location Creation Time Id
The method setToggleRenderer(AbstractRenderer) in the type PGroup is not
applicable for the arguments (AbstractRenderer)
org.eclipse.swt.nebula.examples/src/org/eclipse/swt/nebula/e xamples/parts
PGroupExampleTab.java line 86 1165421637528 1042263
Type mismatch: cannot convert from ChevronsToggleRenderer to
AbstractRenderer
PGroupExampleTab.java line 52 1165421637528 1042259
Type mismatch: cannot convert from MinMaxToggleRenderer to
AbstractRenderer
PGroupExampleTab.java line 56 1165421637528 1042260
Type mismatch: cannot convert from TreeNodeToggleRenderer to
AbstractRenderer
PGroupExampleTab.java line 64 1165421637528 1042262
Type mismatch: cannot convert from TwisteToggleRenderer to
AbstractRenderer
PGroupExampleTab.java line 60 1165421637528 1042261
Is anybody else having this problem? The code looks valid to me; I
suspect it may be a problem in the compiler. I just wanted to check
here before posting a bug report to JDT.
Matthew
| Re: Compiler error in org.eclipse.swt.nebula.examples [message #19999 is a reply to message #19953] |
Wed, 06 December 2006 12:41  |
Chris Gross Messages: 253 Registered: July 2009 |
Sorry Matthew, I've been making changes and some things are committed
some are not.
-Chris
Matthew Hall wrote:
> Found it: the import in PGroupExampleTab was importing the
> AbstractRenderer class in the grid package instead of the pgroup
> package. Patch follows:
> ### Eclipse Workspace Patch 1.0
> #P org.eclipse.swt.nebula.examples
> Index: src/org/eclipse/swt/nebula/examples/parts/PGroupExampleTab.j ava
> RCS file:
> /cvsroot/technology/org.eclipse.swt.nebula/org.eclipse.swt.n ebula.examples/src/org/eclipse/swt/nebula/examples/parts/PGr oupExampleTab.java,v
> retrieving revision 1.5
> diff -u -r1.5 PGroupExampleTab.java
> --- src/org/eclipse/swt/nebula/examples/parts/PGroupExampleTab.j ava
> 25 Oct 2006 19:49:29 -0000 1.5
> +++ src/org/eclipse/swt/nebula/examples/parts/PGroupExampleTab.j ava 6
> Dec 2006 16:31:49 -0000
> @@ -8,8 +8,8 @@
> import org.eclipse.swt.nebula.examples.AbstractExampleTab;
> import org.eclipse.swt.nebula.examples.ButtonFactory;
> import org.eclipse.swt.nebula.examples.ExamplesView;
> -import org.eclipse.swt.nebula.widgets.grid.AbstractRenderer;
> import org.eclipse.swt.nebula.widgets.pgroup.AbstractGroupStrategy;
> +import org.eclipse.swt.nebula.widgets.pgroup.AbstractRenderer;
> import org.eclipse.swt.nebula.widgets.pgroup.ChevronsToggleRenderer ;
> import org.eclipse.swt.nebula.widgets.pgroup.FormGroupStrategy;
> import org.eclipse.swt.nebula.widgets.pgroup.MinMaxToggleRenderer;
| Re: Compiler error in org.eclipse.swt.nebula.examples [message #571727 is a reply to message #19879] |
Wed, 06 December 2006 11:24  |
Matthew Hall wrote:
> Hello everyone,
> Time Id
> AbstractRenderer
> AbstractRenderer
> AbstractRenderer
> AbstractRenderer
> Matthew
Forgot to mention I'm using Eclipse SDK 3.3M3 (I20061102-1715)
| Re: Compiler error in org.eclipse.swt.nebula.examples [message #571761 is a reply to message #19909] |
Wed, 06 December 2006 11:32  |
RCS file:
--- src/org/eclipse/swt/nebula/examples/parts/PGroupExampleTab.j ava 25
@@ -8,8 +8,8 @@
| Re: Compiler error in org.eclipse.swt.nebula.examples [message #571803 is a reply to message #19953] |
Chris Gross Messages: 471 Registered: July 2009 |
some are not.
-Chris
> RCS file:
> @@ -8,8 +8,8 @@
FUDForum. Page generated in 0.03592 seconds
