| WTP Book: Deployment descriptor of the module NNN cannot be loaded. [message #199576] |
Tue, 11 September 2007 08:38  |
Steve Jones Messages: 92 Registered: July 2009 |
Member |
Following the LeaguePlanet example in the WTP book I've now got as far
as chapter 8, page 352. I have three errors relating to the
LeaguePlanetEAR project:
1. IWAE0053E An internal error has occurred running validation on
project:LeaguePlanetEAR] deployment descriptor of the module
'LeaguePlanetEJB.jar' cannot be loaded.
2. The deployment descriptor of the module 'LeaguePlanetEJB.jar'
cannot be loaded.
3. The deployment descriptor of the module 'LeaguePlanetWeb.war'
cannot be loaded.
In LeaguePlanetEAR/.settings/org.eclipse.wst.common.component, if I
remove the dependency:
<dependent-module deploy-path="/"
handle="module:/resource/LeaguePlanetWeb/LeaguePlanetWeb">
<dependent-object>WebModule_1189505806557</dependent-object >
<dependency-type>uses</dependency-type>
</dependent-module>
Only error 3 remains and magically the internal error is no longer
reported. I can only assume the error is somthing to do with the
location or content of the LeaguePlanetWeb deployment file:
LeaguePlanetWeb\WebContent\WEB-INF\web.xml
This file exists and seems to have sensible things in it.
I've redone the example several time using a clean workspace with the
same result each time.
This is all on Europa/WTP 2.0.
Any clue as to how I might resolve this would be much appreciated.
Thanks, Steve.
| Re: WTP Book: Deployment descriptor of the module NNN cannot be loaded. [message #199686 is a reply to message #199576] |
Thu, 13 September 2007 09:30  |
Naci Dai Messages: 55 Registered: July 2009 |
Member |
Steve,
The book is based on WTP 1.5.x. However, there are some readers who
used 2.0 to complete the exercises. Thx for reporting your experiences
with it.
A common problem is related to using JEE5 level facets for Ear/Web/Ejb
projects (5/2.5/3.0). WTP 2.0 has bare minimum support for JEE5. If
that is the problem, you can use versions that are fully supported (Ear
1.4, Servlet 2.4, Ejb 2.1)
There are some notes we keep at the book site to answer common problems
http://www.eclipsewtp.org/errata.html
feedback at eclicpse.wtp.org
> cannot be loaded.
> cannot be loaded.
> </dependent-module>
> Thanks, Steve.
FUDForum. Page generated in 0.01585 seconds
