Home » Eclipse Projects » Web Tools Project (WTP) » Web App Deployment
Web App Deployment [message #199289] Fri, 31 August 2007 12:22 Go to next message
Eclipse User
Originally posted by: gmrenak.topdownsoftware.com
Eclipse 3.2.1
How does eclipse determine what to include in a WAR file when it's
deployed? I think I learned the hard way that simply placing a related
project on the Web-app's build path doesn't do it.
Gary
Re: Web App Deployment [message #199321 is a reply to message #199289] Sun, 02 September 2007 21:25 Go to previous messageGo to next message
Zhaoming Lin is currently offline Zhaoming Lin
Hi Gary,
I think the content of exported war file is determined by the component
file.
..settings/org.eclipse.wst.common.component.
You can change the source and deploy path in the web-resource xml element.
"Gary Mrenak" <gmrenak@topdownsoftware.com> wrote in message
news:fb9fjk$h11$2@build.eclipse.org...
> Eclipse 3.2.1
> Gary
Re: Web App Deployment [message #199329 is a reply to message #199321] Mon, 03 September 2007 08:30 Go to previous messageGo to next message
Eclipse User
zhaoming lin wrote:
> Hi Gary,
> file.
>> Eclipse 3.2.1
>> Gary
Thanks very much ... I had no idea those ".settings" files were there.
Now it will be much simpler to experiment and see what particular
Eclipse actions cause WAR file inclusions.
Gary
Re: Web App Deployment [message #199359 is a reply to message #199329] Tue, 04 September 2007 10:05 Go to previous message
Rob Frost is currently offline Rob Frost
Member
It is not just the component file: project classpath entries can also be
bundled into the WAR (in WEB-INF/lib) if those entries have the appropriate
WTP attribute.
Management of WEB-INF/lib dependencies (whether persisted in the component
file or via a classpath entry attribute) is done via the J2EE Module
Dependencies UI.
-Rob
news:fbgv3k$97v$1@build.eclipse.org...
> zhaoming lin wrote:
>> Hi Gary,
>> file.
>> element.
>>> Eclipse 3.2.1
>>> Gary
> Thanks very much ... I had no idea those ".settings" files were there. Now
> it will be much simpler to experiment and see what particular Eclipse
> Gary
Previous Topic:Deleting files in "project explorer" doesn't remove them from that view
Next Topic:New JSDT Feature Demos Available
Current Time: Sat May 25 01:25:41 EDT 2013
Powered by FUDForum. Page generated in 0.17211 seconds
