| connecting object [message #1895] |
Wed, 08 October 2008 04:52  |
faroun Messages: 41 Registered: July 2009 |
Member |
Hi everybody ,
i'm trying to connect bpmn object inside of a diagram .
i'm localising object based on there position .
Can i get Object giving it's position so i can use the addSequenceEdge().
Best Regards ,
Dali.
| Re: connecting object [message #1909 is a reply to message #1895] |
Wed, 08 October 2008 06:11   |
Originally posted by: atoulme.intalio.com
Aren't you generating the whole diagram ? In that case, don't you have
the Activity elements you created with addActivity somewhere ?
The object position is not set as long as the generateViews method is
not called. Once the generateViews method is called, you should not add
more semantic elements.
Antoine
faroun wrote:
> Hi everybody ,
> Best Regards ,
> Dali.
| Re: connecting object [message #1965 is a reply to message #1952] |
Thu, 09 October 2008 11:10   |
Dali,
the Activity class extends the Vertex class. So there is no
transformation to do, just go ahead and punch them as parameters of the
method, everything should compile and run.
Antoine
dali wrote:
> Hi antoine ,
> i'm still trying to create connections between the bpmn object i'm
> creating.
> My question is how can transform activities into vertex ( so i can pass
> it to the addSequenceEdge() Method) .
> Best Regards ,
> Dali.
| Re: connecting object [message #1993 is a reply to message #1979] |
Fri, 10 October 2008 06:45  |
It depends what you mean by interfering ?
Please attach a screenshot.
If you mean that the sequence edges are being drawn over tasks, then the
solution is to arrange the tasks by using the arrange all toolbar button.
Antoine
Dali wrote:
> Hi antoine ,
> Thanx a lot . it works :)) . Now the links are created but they are
> interfering with some objects.
> i'm trying to enhance shifting between object but still some problems.
> is there a solution to fix this.
> Best Regards,
> Dali
FUDForum. Page generated in 0.01874 seconds
