We are working on an open source project with xml configuration editor
user interface requirements similar to the web.xml configuration editor
(the web deployment descriptor).
Is there a way to reuse this code as part of a plugin or extend it to be
launched as the default editor for our xmls?
I was pointed to the
org.eclipse.wst.xml.ui.internal.tabletree.XMLMultiPageEditor Part but did
not find this to be the entry class for the UI editor. Is there a way to
understand the class "call" structure to resue the web deployment
descriptor code?
Or, rephrasing the question -- which is the class that's called first when
a web.xml is double-clicked?
Please point out if my understanding is incorrect and there is a
better/smarter way to achive what I want to do, please suggest.
Also, I am assuming that the user interface is laid out (rendered) using a
standard xml doc descriptor (dtd or xsd) that creates the place holders
for the web.xml's elements. Your thoughts!
Would anyone recommend additional resources/docs to follow?
WTP does not provide any special editor for web.xml files. When you
go to a web.xml file and look at the "Open With" context menu, are
you opening something other than the "XML Editor"?
