| Problem after installing language pack for Eclipse Europa [message #19716] |
Tue, 16 September 2008 12:18  |
chaitanya tangudu Messages: 6 Registered: July 2009 |
Junior Member |
I had installed the Language pack for Eclipse Europa (3.3.2) through
the update site
http://download.eclipse.org/technology/babel/update-site/eur opa
But after that I have quite a few problems. Please let me know if you have
encountered similar problems or anything wrong am I doing.
1. It some times shows up & some times doesn't show, the new language
packages info. in the product configuration.
2. When the info. doesn't come up, then there happens some serious problem
in the JRE, like we couldn't able to open the JRE dialog, it throws the
exception as below with some compilation error in the code.
Plug-in org.eclipse.jdt.debug.ui was unable to load class
org.eclipse.jdt.internal.debug.ui.jres.JREContainerWizardPag e.
An error occurred while automatically activating bundle
org.eclipse.jdt.debug.ui (85).
3. When I start eclipse with other languages (like French), some workbench
menus still come in English.
So any help/hint to the the solution of this problems is highly
appriceated & thanks in advance.
| Re: Problem after installing language pack for Eclipse Europa [message #19772 is a reply to message #19716] |
Fri, 19 September 2008 10:38  |
Eclipse Webmaster Messages: 145899 Registered: July 2009 |
Comments below...
chaitanya tangudu wrote:
> the update site
> have encountered similar problems or anything wrong am I doing.
Is there a reproduceable pattern? When I install a language pack and
launch Eclipse with the -nl option, it always shows up.
> problem in the JRE, like we couldn't able to open the JRE dialog, it
> throws the exception as below with some compilation error in the code.
There could be a bad translation somewhere, but without the full stack
it's hard to tell.
> workbench menus still come in English.
The translations are a community effort, and they are not complete
(yet). You can help out by logging into the Babel server and
translating those strings: http://babel.eclipse.org/
Thanks!
Eclipse WebMaster - webmaster@eclipse.org
Questions? Consult the WebMaster FAQ at
http://wiki.eclipse.org/index.php/Webmaster_FAQ
View my status at http://wiki.eclipse.org/index.php/WebMaster
| Re: Problem after installing language pack for Eclipse Europa [message #573786 is a reply to message #19716] |
Comments below...
> the update site
it's hard to tell.
Thanks!
FUDForum. Page generated in 0.02117 seconds
