Home » Eclipse Projects » Web Tools Project (WTP) » Can I install WebTools IN ADDITION to eclipse ?
Can I install WebTools IN ADDITION to eclipse ? [message #197445] Sat, 28 July 2007 05:39 Go to next message
Eclipse User
Originally posted by: thoste.email.com
As far as I can see the WebTools package contains the "normal/standard"
eclipse packages as well.
Because I have already installed Eclipse on my computer and I don't want
neither to install a second Eclipse nor to touch the existing Eclipse
installation I am searching for a way just to install the additional
WebTools specific components and use (if necessary) the existing Eclipse.
is this possible ?
When can I download the WebTools-only part of the full WebTools+Eclipse
package ?
Thomas
Re: Can I install WebTools IN ADDITION to eclipse ? [message #197461 is a reply to message #197445] Sat, 28 July 2007 10:38 Go to previous message
David Carver is currently offline David Carver
> is this possible ?
> package ?
You can do that now, if you have Europa or Calisto version of Eclipse
installed. Just use the Software Updates -> Find Install New Features
and select the Europa Discovery or Callisto Discovery sites. You can
then select the Web Tools Platform packages to install into your
existing Eclipse environment.
Dave
Previous Topic:EJB with JBoss 4.0.x
Next Topic:WSDL 2.0 Support
Current Time: Tue May 21 02:17:56 EDT 2013
Powered by FUDForum. Page generated in 0.01713 seconds
