Home » Eclipse Projects » Web Tools Project (WTP) » Some Problem during launching websphere 6.1 from eclipse WTP 1.5.3
Some Problem during launching websphere 6.1 from eclipse WTP 1.5.3 [message #196268] Thu, 12 July 2007 06:45 Go to next message
Eclipse User
Originally posted by: debabrata.pani.gmail.com
I have some problem while starting up websphere 6.1 from eclipse WTP 1.5.3.
I debugged into the eclipse code and this is what i observe. A thread is
trying to stop the server and that is preventing the PingingThread from
actually finding out the status of the server and setting the
"serverState" variable . The trial version of Websphere 6.1 that I have
installed has automatically installed itself as a window service. Can this
be the reason for this behavior. In the installation of Websphere 6.0 ,
which is not made into a window service, I haven't observed this problem.
As a consequence of this stopping of the server, eclipse throws an
Exception without any stack trace. Just a single line of error saying that
"Websphere 6.1 couldn't be started"
Thread [Worker-10] (Suspended (breakpoint at line 478 in
GenericServerBehaviour))
GenericServerBehaviour.stopImpl() line: 478
GenericServerBehaviour$1.handleDebugEvents(DebugEvent[]) line: 468
DebugPlugin$EventNotifier.run() line: 1076
SafeRunner.run(ISafeRunnable) line: 37
DebugPlugin$EventNotifier.dispatch(DebugEvent[]) line: 1108
DebugPlugin$EventDispatchJob.run(IProgressMonitor) line: 344
Worker.run() line: 58
Re: Some Problem during launching websphere 6.1 from eclipse WTP 1.5.3 [message #196328 is a reply to message #196268] Thu, 12 July 2007 10:01 Go to previous messageGo to next message
Angel Vera is currently offline Angel Vera
Member
Try removing WAS 6.1 from running as a service. In the bin directory there
is a wasservice executable that you can use.
debabrata.pani@gmail.com (Debabrata Pani) wrote in
news:42a4e6ad4e3adb9e02b64b241824b920$1@www.eclipse.org:
Angel Vera
WTP Server Tools Developer
Re: Some Problem during launching websphere 6.1 from eclipse WTP 1.5.3 [message #196375 is a reply to message #196328] Thu, 12 July 2007 10:38 Go to previous messageGo to next message
Eclipse User
Hi Angel Vera,
Thanx for your suggestion. But i don't understand your point about using
the startServer.bat file. Since I am using the WTP to launch the server
and publish the projects, I need not use the startServer.bat or any
other batch file publishing, isn't it ? That is what I feel. Please
explain if I m wrong.
Thanx again.
Re: Some Problem during launching websphere 6.1 from eclipse WTP 1.5.3 [message #196384 is a reply to message #196375] Thu, 12 July 2007 10:50 Go to previous messageGo to next message
Member
Hi Debabrata,
You were saying that you suspect that the problem us because your WAS is
installed as a Windows Services. If you think that is the problem, you
can confirm it by removing WAS from running as a Windows Service. To
remove WAS from running as a Windows Service you can use the bin
\wasservice.exe -remove <serviceName> to remove WAS 6.1 to be run as a
Windows Service.
Debabrata Pani <debabrata.pani@gmail.com> wrote in
news:f75efj$ovq$1@build.eclipse.org:
>> there is a wasservice executable that you can use.
> Hi Angel Vera,
> using the startServer.bat file. Since I am using the WTP to launch the
> server and publish the projects, I need not use the startServer.bat or
> any other batch file publishing, isn't it ? That is what I feel.
> Please explain if I m wrong.
> Thanx again.
Angel Vera
Re: Some Problem during launching websphere 6.1 from eclipse WTP 1.5.3 [message #196412 is a reply to message #196384] Fri, 13 July 2007 01:30 Go to previous messageGo to next message
Eclipse User
Hi Angel,
I removed the WAS 6.1 from the service(Thanx for your help) and tried to
start the server from the WTP. But it failed again, with a new error
message. The paths of JRE/JAVA are all properly set as such. The
particular executable that is supposed to be invalid(by eclipse WTP) has
been found to work properly. If you paste that executable to the command
line, it runs but gives the help instructions as the output.
The error output is as shown below:
ADMU0116I: Tool information is being logged in file
C:\IBM2\WebSphere\AppServer\profiles\AppSrv01\logs\server1\s tartServer.log
ADMU0128I: Starting tool with the AppSrv01 profile
ADMU3100I: Reading configuration for server: server1
ADMU0111E: Program exiting with error:
com.ibm.ws.process.exception.InvalidExecutableException:
PROC0004E:
Executable: [C:/IBM2/WebSphere/AppServer/java/bin/java] does not
appear to be a valid executable. Process could not be created.
ADMU1211I: To obtain a full trace of the failure, use the -trace option.
ADMU0211I: Error details may be seen in the file:
C:/IBM2/WebSphere/AppServer/profiles/AppSrv01\logs\server1\s tartServer.log
Angel Vera wrote:
> Hi Debabrata,
> Windows Service.
>> Hi Angel Vera,
>> Thanx again.
Re: Some Problem during launching websphere 6.1 from eclipse WTP 1.5.3 [message #196443 is a reply to message #196412] Fri, 13 July 2007 10:26 Go to previous messageGo to next message
Member
Hi Debabrata,
That is as far as I can go to help you with this problem. I don't own
the WAS WTP server adapters, but I do have some knowledge about them. I
was trying to help you out, but someone else is going to have to take
over, or you can open a bugzilla.
news:f772p5$20b$1@build.eclipse.org:
> Hi Angel,
> to start the server from the WTP. But it failed again, with a new
> error message. The paths of JRE/JAVA are all properly set as such. The
> has been found to work properly. If you paste that executable to the
> command line, it runs but gives the help instructions as the output.
\startServer.
> log ADMU0128I: Starting tool with the AppSrv01 profile
> PROC0004E:
> does not appear to be a valid executable. Process could
> not be created.
> option. ADMU0211I: Error details may be seen in the file:
\startServer.
> log
> Angel Vera wrote:
>> Hi Debabrata,
>> is installed as a Windows Services. If you think that is the problem,
>> you can confirm it by removing WAS from running as a Windows Service.
>> To remove WAS from running as a Windows Service you can use the bin
>> a Windows Service.
>>>> directory there is a wasservice executable that you can use.
>>> Hi Angel Vera,
>>> the server and publish the projects, I need not use the
>>> startServer.bat or any other batch file publishing, isn't it ? That
>>> is what I feel. Please explain if I m wrong.
>>> Thanx again.
Angel Vera
Re: Some Problem during launching websphere 6.1 from eclipse WTP 1.5.3 [message #196652 is a reply to message #196443] Wed, 18 July 2007 10:14 Go to previous message
Eclipse User
Thanx man, anyway for the help.
Ciao !
Angel Vera wrote:
> Hi Debabrata,
>> Hi Angel,
> \startServer.
>> PROC0004E:
>> not be created.
> \startServer.
>> log
>> Angel Vera wrote:
>>> Hi Debabrata,
>>> a Windows Service.
>>>> Hi Angel Vera,
>>>> Thanx again.
Previous Topic:When I install WTP I meet Install bundel error.
Next Topic:Tomcat 6 and Eclipse 3.3 trouble
Current Time: Tue May 21 23:33:52 EDT 2013
Powered by FUDForum. Page generated in 0.01819 seconds
