Home » Eclipse Projects » Web Tools Project (WTP) » Publish on Server not usefull for dynamic web applcations
Publish on Server not usefull for dynamic web applcations [message #194328] Tue, 12 June 2007 12:56 Go to next message
Eclipse User
Originally posted by: tjerk.wolterinkwebdesign.com
Suppose you build a web application that creates files in the /web dir
dynamically...
Each time you change code the app will be republished:
this means that all the dynamical created files/dirs are deleted...
And probable you have a database that refers to these files
-> conclusion your published application is out of sync.
: Solution: Make it able to tag some dirs in your application
ass 'dynamic' such that a republish does not delete files
from that directory.
Re: Publish on Server not usefull for dynamic web applcations [message #195940 is a reply to message #194328] Tue, 10 July 2007 10:56 Go to previous messageGo to next message
Eclipse User
Damn, is there not anyone who knows the solution???????
> dynamically...
Re: Publish on Server not usefull for dynamic web applcations [message #195964 is a reply to message #195940] Tue, 10 July 2007 11:13 Go to previous messageGo to next message
Eclipse User
Originally posted by: ns_dkerber.ns_WarrenRogersAssociates.com
In article <f706mv$em3$1@build.eclipse.org>,
tjerk@wolterinkwebdesign.com says...
What is the question? I don't see you asking anything here, just making
statements...
> > dynamically...
Remove the ns_ from if replying by e-mail (but keep posts in the
newsgroups if possible).
Re: Publish on Server not usefull for dynamic web applcations [message #195980 is a reply to message #195940] Tue, 10 July 2007 11:33 Go to previous messageGo to next message
Eclipse User
>> dynamically...
I ran into the same problem. What I did was move those files (images)
into their own directory structure, still in the webapp directory but
separate from the application. So a republish of the application does
not touch those files:
webapp
- app
-- WebRoot
-- etc
- files
-- app
--- image files
Wojtek :-)
Re: Publish on Server not usefull for dynamic web applcations [message #196065 is a reply to message #195940] Wed, 11 July 2007 11:23 Go to previous message
Eclipse User
>> dynamically...
webapp
- app
-- WebRoot
-- etc
- files
-- app
--- image files
Wojtek :-)
Previous Topic:Code assist closing tag
Next Topic:WTP 2.0 Debugging Question
Current Time: Mon May 20 16:49:17 EDT 2013
Powered by FUDForum. Page generated in 0.01561 seconds
