Home » Eclipse Projects » Web Tools Project (WTP) » Migrating from JBuilder to Europa using Resin
Migrating from JBuilder to Europa using Resin [message #195926] Tue, 10 July 2007 06:48 Go to next message
Eclipse User
Originally posted by: john.steel.phonewebcam.com
I'm following http://www.bachansoft.com/tutorials/web/eclipse_resin.html
which seems to be pre-Europa, but have a question anyway.
When you define a server using Window | Preferences | Installed Runtimes |
Add.. you are asked to point to a folder which contains the servers
libraries. This then appears under Libraries in the Java Resources: src
leaf of the project tree. Resin/JBuilder can use ant-style folder
recursion such that all the jars in lib/ and it subfolders are picked up.
This is useful for placing 3rd party (to Resin) libs and internally
developed ones, which are server wide. I thought for a moment the server
definition in "Edit Server Runtime" would allow multiple paths in the
Location: field separated by ;, but its not so. I have defined separate
libraries for each explicit path and use Build Path... in the project tree
to add them.
This is cumbersome as we have many JBuilder projects. Have I missed
something please? Thanks.
-- John
http://www.phonewebcam.com
Re: Migrating from JBuilder to Europa using Resin [message #195988 is a reply to message #195926] Tue, 10 July 2007 11:50 Go to previous messageGo to next message
Angel Vera is currently offline Angel Vera
Member
Have you tried using the User libraries preferences, you may find it
handy and is probably what you want to do..?
Window -> Preferences -> Java -> Build Path -> User Libraries
john.steel@phonewebcam.com (John Steel) wrote in
news:94e07d1265eee82c7ee9817ed363aa2c$1@www.eclipse.org:
> I'm following
> http://www.bachansoft.com/tutorials/web/eclipse_resin.html which seems
> Runtimes | Add.. you are asked to point to a folder which contains the
> servers libraries. This then appears under Libraries in the Java
> Resources: src leaf of the project tree. Resin/JBuilder can use
> ant-style folder recursion such that all the jars in lib/ and it
> subfolders are picked up. This is useful for placing 3rd party (to
> Resin) libs and internally developed ones, which are server wide. I
> thought for a moment the server definition in "Edit Server Runtime"
> would allow multiple paths in the Location: field separated by ;, but
> its not so. I have defined separate libraries for each explicit path
> and use Build Path... in the project tree to add them.
> -- John
Angel Vera
WTP Server Tools Developer
Re: Migrating from JBuilder to Europa using Resin [message #195996 is a reply to message #195988] Tue, 10 July 2007 15:56 Go to previous message
Eclipse User
Thanks, that was it.
-- John
Previous Topic:Re: Structured Text Editor and EMF Model
Next Topic:What populates ${project_loc}?
Current Time: Sun May 19 01:35:43 EDT 2013
Powered by FUDForum. Page generated in 0.07909 seconds
