| Relative path to datapool [message #17943] |
Fri, 13 May 2005 08:24  |
Originally posted by: roman.bosak.tietoenator.com
I have problem with a path to a datapool file. If I write down the path into
my test class in absolute format
(c:/workspace/%pluginName%/%datapoolFileName%.datapool) everythink works
well. But the absoult path is inconvenient.
If I use relative path then it tries to acces it in C:\Documents and
Settings\%userName%\Local Settings\Temp\%relativePath%. But nobody deploys
the datapool file into this location.
What am I doing wrong?
I also tries to make some artifacts, locations and deployments but without
success :-(
Thanks a lot for your suggestions.
Roman Bos
| Re: Relative path to datapool [message #18696 is a reply to message #17943] |
Tue, 24 May 2005 09:39   |
I workarounded this problem setting SYS_TEMP_DIR variable in
%RASERVER_HOME%/config/serviceconfig.xml to the root directory of my test
resources.
Does anyone know how and where are resources deployed without this
workaround?
(This workaround does not require deployment because the path is hardly
configured to look for resources in their original locations)
Is it possible to deploy also not Hyades files (*.properties, ...)?
(Hayades files I means artifacts - *.datapool, *.testsuit)
"Roman Bos
| Re: Relative path to datapool [message #18918 is a reply to message #18696] |
Thu, 02 June 2005 09:02   |
Holger Machens Messages: 57 Registered: July 2009 |
Member |
Hello Roman (?),
it seems to me, that it's the wrong way to change the SYS_TEMP_DIR variable.
As i remember, you can specify datapools as part (artifact) of your test
in the deployment description.
During deployment, TPTP creates a copy of your execution environment
with jar-files and artifacts needed to execute the test on the target (the
machine were your test shall be executed).
After that, the resource - respectivly your datapool - MUST be located in
a path that is relativ to the execution directory used by the agent controller.
May the force be with you!
Greetings
Holger
> resources.
> workaround?
> "Roman Bosák" <roman.bosak@tietoenator.com> wrote in message
> news:d626q5$t1l$1@news.eclipse.org...
>>Hi,
>>into my test class in absolute format
>>success :-(
>>Roman Bosák
>>ICQ: 163393951
| Re: Relative path to datapool [message #19266 is a reply to message #18918] |
Tue, 07 June 2005 07:15   |
Hi Holger,
"Holger Machens" <machens@informatik.fh-wiesbaden.de> wrote in message
news:d7n00u$fcs$1@news.eclipse.org...
> Hello Roman (?),
> variable.
Yes definetely, but ... :-)
I did.
I think so.
> controller.
The path where is Hyades (or AgentControler) looking for "deployed"
resources is relative to SYS_TEMP_DIR property of the configuration. But it
doesn't deploy them there :-(
> Greetings
> Holger
> Roman Bos
| Re: Relative path to datapool [message #19545 is a reply to message #19266] |
Wed, 08 June 2005 04:10  |
Member |
Hi Roman,
ok, if artifacts are not deployed correctly, it must be a bug and you should enter a bug report in the bugzilla.
http://www.eclipse.org/tptp --> "Submit Enhancements & Bugs" --> "Report a new bug"
This might help the tptp group!
Greetings
Holger
Roman Bosák wrote:
> Hi Holger,
>>Hello Roman (?),
>>variable.
> I did.
> I think so.
>>controller.
>>Greetings
>> Holger
>>>resources.
>>>workaround?
>>>>Hi,
>>>>deploys the datapool file into this location.
>>>>without success :-(
>>>>Roman Bosák
>>>>ICQ: 163393951
FUDForum. Page generated in 0.01604 seconds
