Home » Eclipse Projects » Web Tools Project (WTP) » soap:headerFault not properly serialized?
soap:headerFault not properly serialized? [message #195239] Fri, 29 June 2007 18:48 Go to next message
Johann is currently offline Johann
I'm programmatically generating a WSDL document using the
org.eclipse.wst.wsdl libraries. I set up my
soap:header object and add a soap:headerFault object to it. But when I
serialize the WSDL document to a file, all I get
is the soap:header element and no soap:headerFault element. I'm adding the
soap:headerFault like so
SOAPHeader soapHeader = SOAPFactory.eINSTANCE.createSOAPHeader();
SOAPHeaderFault soapHeaderFault =
SOAPFactory.eINSTANCE.createSOAPHeaderFault();
soapHeader.getHeaderFaults().add(soapHeaderFault);
Here's the result that I get.
<wsdl:input>
<soap:header encodingStyle="soapheaderencodingstyle style2"
message="tns:m1" namespace="soapheadernamespace" part="part1"
use="literal"/>
</wsdl:input>
Before serialization, I am able to browse into my Definition object in the
debugger and confirm that the soap:HeaderFault object is contained in the
soap:Header object.
My org.eclipse.wst.wsdl plugin is v1.0.102.
Is this an serialization problem similar to mime:multipartRelated, or am I
doing something wrong?
Thanks.
Johann
Re: soap:headerFault not properly serialized? [message #195249 is a reply to message #195239] Fri, 29 June 2007 20:38 Go to previous message
Eclipse User
Originally posted by: valentinbaciu.hotmail.com
Yes, this appears to be similar to the MIME bug. It appears the
serialization code is missing. I'm speculating this stayed hidden because
the main client for the model is the WSDL editor and the editor is
manipulating the underlying DOM directly for all extensibility elements.
Please open a bug. Until we get a chance to fix it (best case scenario WTP
1.5.5 and/or 2.0.1) you can use the same approach to add the soap header
faults: manipulate the DOM directly.
Valentin
"Johann" <td_jbrun@yahoo.com> wrote in message
news:f642a2$vt6$3@build.eclipse.org...
> <wsdl:input>
> use="literal"/>
> </wsdl:input>
> soap:Header object.
> Thanks.
> Johann
Previous Topic:about that Web Browser icon on Eclipse ToolBar
Next Topic:strange problem about compiling my first servlet
Current Time: Sun May 19 23:36:30 EDT 2013
Powered by FUDForum. Page generated in 0.01491 seconds
