Home » Eclipse Projects » Web Tools Project (WTP) » Error: Schema "MARCOS" cannot be resolved for table "GE_FUNCIONARIOS"
Error: Schema "MARCOS" cannot be resolved for table "GE_FUNCIONARIOS" [message #194193] Fri, 08 June 2007 12:43 Go to next message
Marcos is currently offline Marcos
Member
- Eclipse 3.3RC2 (Build id: I20070525-1350)
- WTP 2.0RC2 (complete)
- Java 5 Update 11
- JBoss 4.2.0GA
Hello, everybody!
I'm getting the following error at design time in an EJB 3.0 project:
This table, GE_FUNCIONARIOS, exists in my database. This is the content of
my
persistence.xml file:
<persistence version="1.0" xmlns="http://java.sun.com/xml/ns/persistence"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://java.sun.com/xml/ns/persistence
http://java.sun.com/xml/ns/persistence/persistence_1_0.xsd">
<persistence-unit name="laboratorio-informatica">
<provider>org.hibernate.ejb.HibernatePersistence</provider >
<jta-data-source>java:/LaboratorioInformaticaDS</jta-data-source >
<class>br.urca.www.laboratorioinformatica.entidade.Funcionario </class>
<!-- other classes -->
<properties>
<property name="hibernate.dialect"
value="org.hibernate.dialect.HSQLDialect" />
<property name="hibernate.hbm2ddl.auto" value="create-drop" />
</properties>
</persistence-unit>
</persistence>
And this is the configuration of the datasource referenced in the element
<jta-data-source> in the file
C:\jboss-4.2.0.GA\server\default\deploy\laboratorio-informat ica-ds.xml:
<!-- $Id: mssql-ds.xml 61002 2007-02-28 16:13:00Z weston.price@jboss.com $
<datasources>
<local-tx-datasource>
<jndi-name>LaboratorioInformaticaDS</jndi-name>
<connection-url>jdbc:sqlserver://SERVDEG;databaseName=DBTESEUS</connection-url>
<driver-class>com.microsoft.sqlserver.jdbc.SQLServerDriver</driver-class >
<user-name>MARCOS</user-name>
<password><!-- there's a valid password here --></password>
<!-- corresponding type-mapping in the standardjbosscmp-jdbc.xml
(optional) -->
<metadata>
<type-mapping>MS SQLSERVER2000</type-mapping>
</metadata>
</local-tx-datasource>
</datasources>
This datasource configuration is valid as the server doesn't report any
problem
about it when it is started.
This is my mapped class:
package br.urca.www.laboratorioinformatica.entidade;
import javax.persistence.Column;
import javax.persistence.Entity;
import javax.persistence.Id;
import javax.persistence.Table;
@Entity
@Table(name = "GE_FUNCIONARIOS") // Error message is here
public class Funcionario
private String fMatricula;
@Id
@Column(name = "MATRICULA")
public String getMatricula()
return fMatricula;
public void setMatricula(String matricula)
fMatricula = matricula;
So, I would like to know what I'm doing wrong to get this error and how
I solve it.
Thank you.
Marcos
Re: Error: Schema "MARCOS" cannot be resolved for table "GE_FUNCIONARIOS" [message #194209 is a reply to message #194193] Sat, 09 June 2007 08:12 Go to previous messageGo to next message
Eclipse User
Originally posted by: chrisjames64.hotmail.co.uk
I was recently playing with a JPA project and found I had to add the
following into the META-INF\orm.xml...
<entity-mappings xmlns="http://java.sun.com/xml/ns/persistence/orm"
xsi:schemaLocation="http://java.sun.com/xml/ns/persistence/orm
http://java.sun.com/xml/ns/persistence/orm_1_0.xsd" version="1.0">
<persistence-unit-metadata>
<persistence-unit-defaults>
<schema>CUSTSCH</schema>
</persistence-unit-defaults>
</persistence-unit-metadata>
</entity-mappings>
An alternative would be to use the schema attribute of the @Table
annotation in the persistent class, but this would be inflexible for
deployments to different environments. e.g
@Entity
@Table(name="", schema="")
public class Customer implements Serializable {
...etc...
Hope this helps
Chris
Re: Error: Schema "MARCOS" cannot be resolved for table "GE_FUNCIONARIOS" [message #194264 is a reply to message #194209] Mon, 11 June 2007 09:39 Go to previous message
Member
Hello, Chris.
I did what you said, but unfortunately it didn't work to me. I don't know
if it is because my project is an EJB Project, not a JPA Project. But I
think that this shouldn't matter. At least that's what I think.
Marcos
> following into the META-INForm.xml...
> </entity-mappings>
> @Entity
> ...etc...
> Hope this helps
> Chris
Previous Topic:Database default schema handling
Next Topic:Unable to Export as .aar
Current Time: Sun May 19 19:40:21 EDT 2013
Powered by FUDForum. Page generated in 0.01497 seconds
