Home » Eclipse Projects » Web Tools Project (WTP) » Multiple webRoots in WTP
Multiple webRoots in WTP [message #193153] Fri, 25 May 2007 14:02 Go to next message
Adam Carbone is currently offline Adam Carbone
Other products/projects (the only thing I do like about Idea) allow you to
specify multiple web folders. They combine them to a temp location or
something before deploying even allow you to use inclusion/exclusion
patterns. Would be nice to integrate a system similar to the way we specify
the java source.
We have a system that has shared web modules between apps and it would be
usefull to be able to set up my system the way it is checked out. currently
we have an at task that runs to combine this. which doens't facilitate easy
web development.
I would even volunteer to help build the system to do this, if someone could
point me in the right direction of where to look.
Adam Carbone
Software Engineer
Verisign Inc.
Re: Multiple webRoots in WTP [message #193596 is a reply to message #193153] Wed, 30 May 2007 07:31 Go to previous messageGo to next message
Kaloyan Raev is currently offline Kaloyan Raev
Hi Adam,
I suggest that a good starting point is to file a feature enhancement in the
bugzilla:
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Web%20To ols&bug_severity=enhancement
Please, describe in details how do you see this feature implemented: how the
project layout should change, what wizard pages and properties pages are
needed and how do they look. Attach screenshots if possible. Please, post
back in the forum the number of the bug you have filed.
I think that if the feature is described well it has it chances to be
implemented in WTP 3.0.
Of course, if you are willing to help with the development you may start
looking at the source code in the org.eclipse.jst.j2ee.web plugin.
Greetings,
Kaloyan
"Adam Carbone" <acarbs12@yahoo.com> wrote in message
news:f378b9$6r0$1@build.eclipse.org...
> specify the java source.
> currently we have an at task that runs to combine this. which doens't
> facilitate easy web development.
> could point me in the right direction of where to look.
> Adam Carbone
> Software Engineer
> Verisign Inc.
Re: Multiple webRoots in WTP [message #193620 is a reply to message #193596] Wed, 30 May 2007 09:13 Go to previous messageGo to next message
Rob Frost is currently offline Rob Frost
Member
You may want to add yourself to the cc list for some of these existing
related enhancements:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=163221: Support
exclusion/inclusion filtering for virtual component wb-resource mappings
https://bugs.eclipse.org/bugs/show_bug.cgi?id=133359: Add UI for .component
file
https://bugs.eclipse.org/bugs/show_bug.cgi?id=107039: We should have a
resource mapping tool for flexible projects
-Rob
"Kaloyan Raev" <kaloyan.raev@sap.com> wrote in message
news:f3jnag$mrj$1@build.eclipse.org...
> Hi Adam,
> the bugzilla:
> the project layout should change, what wizard pages and properties pages
> are needed and how do they look. Attach screenshots if possible. Please,
> post back in the forum the number of the bug you have filed.
> Greetings,
> Kaloyan
>> to specify multiple web folders. They combine them to a temp location or
>> Adam Carbone
>> Software Engineer
>> Verisign Inc.
Re: Multiple webRoots in WTP [message #194034 is a reply to message #193153] Wed, 06 June 2007 03:43 Go to previous message
Eclipse User
Originally posted by: mauro.molinari.cardinis.com
Hello Adam!
Have a look to my post of 04/04/2007 with subject 'Multiple "WebContent"
folders': I have written a way to achieve what you need, but I still
miss a "clean" way to do this using Eclipse UI...
Thanks to Rob for pointing out those existing bug reports.
Mauro
Previous Topic:test
Next Topic:Disabling WTP related Preference pages
Current Time: Tue May 21 12:56:53 EDT 2013
Powered by FUDForum. Page generated in 0.01723 seconds
