| JDBC Realm [message #192434] |
Sun, 13 May 2007 05:27  |
Zohar Amir Messages: 419 Registered: July 2009 |
Using eclipse 3.3 and WTP 2.0 (milestones).
I use WTP with tomcat 5.5. . I am trying to configure tomcat to authenticate
users using a JDBC realm. I have changed the server.xml file in
\.metadata\.plugins\org.eclipse.wst.server.core\tmp0\conf\se rver.xml, and
added this line:
<Realm className="org.apache.catalina.realm.JDBCRealm" connectionName="myDB"
connectionPassword="passy"
connectionURL="jdbc:sqlserver://127.0.0.1:1433;DatabaseName=DB1;SelectMethod=cursor"
driverName="com.microsoft.sqlserver.jdbc.SQLServerDriver" roleNameCol="Role"
userCredCol="Password" userNameCol="Username" userRoleTable="UserRoles"
userTable="Users"/>
and then place the JDBC driver jar in
\.metadata\.plugins\org.eclipse.wst.server.core\tmp0\common\ lib
This used to work before, but now (I think it is since I changed to eclipse
3.3 / WTP 2.0) I get this:
SEVERE: Exception opening database connection
java.sql.SQLException: com.microsoft.sqlserver.jdbc.SQLServerDriver
at org.apache.catalina.realm.JDBCRealm.open(JDBCRealm.java:689)
at org.apache.catalina.realm.JDBCRealm.start(JDBCRealm.java:766 )
at org.apache.catalina.core.ContainerBase.start(ContainerBase.j ava:1005)
at org.apache.catalina.core.StandardEngine.start(StandardEngine .java:442)
at org.apache.catalina.core.StandardService.start(StandardServi ce.java:450)
at org.apache.catalina.core.StandardServer.start(StandardServer .java:709)
at org.apache.catalina.startup.Catalina.start(Catalina.java:551 )
at org.apache.catalina.startup.Bootstrap.start(Bootstrap.java:2 94)
at org.apache.catalina.startup.Bootstrap.main(Bootstrap.java:43 2)
Any idea...?
| Re: JDBC Realm [message #193471 is a reply to message #193261] |
Tue, 29 May 2007 08:59  |
Larry Isaacs Messages: 1261 Registered: July 2009 |
Zohar wrote:
> Thanks Larry.
> What is the difference between catalina.home and catalin.base?
See:
http://www.eclipse.org/webtools/faq/TomcatServerFAQ.php#gett ing_started_2
where are
> they set?
catalina.home is tied to the Tomcat runtime the server is associated
with. Since you are using WTP 2.0, catalina.base can be controlled
using the server editor and the new section shown at the bottom of:
http://www.eclipse.org/webtools/development/news/2.0M6/serve r.php
Larry
> "Larry Isaacs" <Larry.Isaacs@sas.com> wrote in message
> news:f29nkv$oca$1@build.eclipse.org...
>> The server.xml to change is the one under the Servers project in your
>> workspace. It will overwrite the one under ".metadata" directory when
>> the server is published. The jar will need to go in the common/lib of
>> your installation, unless you have modified the "common.loader"
>> property in the catalina.properties file (also under the Servers
>> project). To appear in the common classloader, the jar would need to
>> be located where it will be included by one of the path definitions in
>> the "common.loader" setting. These path definitions typically derive
>> from catalina.home (the installation) rather than catalina.base.
>> Cheers,
>> Larry
>> Zohar wrote:
>>> Hi,
>>> authenticate users using a JDBC realm. I have changed the server.xml
>>> file in
>>> and added this line:
>>> connectionName="myDB" connectionPassword="passy"
>>> roleNameCol="Role" userCredCol="Password" userNameCol="Username"
>>> userRoleTable="UserRoles" userTable="Users"/>
>>> eclipse 3.3 / WTP 2.0) I get this:
>>> at
>>> at
>>> at
>>> at
>>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>>> at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
>>> at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
>>> at java.lang.reflect.Method.invoke(Unknown Source)
>>> Any idea...?
FUDForum. Page generated in 0.01669 seconds
