Home » Eclipse Projects » Voicetools » FYI: Converting an Application to an Application Fragment
FYI: Converting an Application to an Application Fragment [message #19259] Tue, 23 September 2008 13:04
Randy Childers is currently offline Randy Childers
This, at the moment, is a manual process.
Before beginning, make a backup copy of your project!
1) I recommend deleting any ³End Call² blocks from the application prior to
the conversion. Save the project, close Eclipse.
2) .project changes
[original application file]
<buildSpec> <buildCommand>
<name> org.eclipse.vtp.desktop.projects.core.VoiceApplicationBuilde r </name>
<arguments> </arguments> </buildCommand> </buildSpec> <natures>
<nature> org.eclipse.vtp.desktop.projects.core.VoiceApplicationNature </nature
> </natures>
[changes to the file]
<name> org.eclipse.vtp.desktop.projects.core.VoiceApplicationFragme ntBuilder <
/name> <arguments> </arguments> </buildCommand> </buildSpec> <natures>
<nature> org.eclipse.vtp.desktop.projects.core.VoiceApplicationFragme ntNature
</nature> </natures>
3) Rename CallDesign.xml ---> CallDesign.frag
4) Edit the CallDesign.frag document
[xml element renames]
<application-definition> ---> <fragment-definition>
<application> ---> <fragment>
(don¹t forget to change the end tags as well, e.g. </application> to
</fragment>)
[begin block changes]
This will be the first primitive element in the design document.
Original application file:
<primitive-element id="cbb0fc79382a4f039e6f8eb5fef8b1cd" name="Begin"
type="org.eclipse.vtp.desktop.editors.core.appbegin"> <bindings
xmlns="http://eclipse.org/vtp/xml/configuration/attacheddata" />
<custom-config xmlns="http://www.eclipse.org/vtp/namespaces/config">
<declarations>
<variable multiplicity="0" name="IncomingVar" type="String" value="no"
value-type="0" /> </declarations> </custom-config> </primitive-element>
Changes to the file:
Fragment" type="org.eclipse.vtp.desktop.editors.core.beginFragment">
<bindings xmlns="http://eclipse.org/vtp/xml/configuration/attacheddata" />
<declarations> <variable multiplicity="0" name="IncomingVar" type="String"
value="no" value-type="0" /> </declarations> </custom-config>
5) Re-launch eclipse and the project should now be listed as a fragment.
Previous Topic:Custom module development for vtp 3.0
Next Topic:FYI: Converting an Application to an Application Fragment
Current Time: Thu May 23 00:20:42 EDT 2013
Powered by FUDForum. Page generated in 0.02032 seconds
