Home » Eclipse Projects » Web Tools Project (WTP) » Workshop for Weblogic Platform 9.2 on Mac OS X 10.4
Workshop for Weblogic Platform 9.2 on Mac OS X 10.4 [message #192132] Sat, 05 May 2007 10:38 Go to next message
Eclipse User
Originally posted by: eclipse.newsgroups.javafreelancer.net
hi all,
i have successfully installed weblogic server 9.2 mp1 (wls) onto my
powermac g4 with os x 10.4.9. i used bea's "generic" installer to do this.
the generic installer is an executable jar file that contains the bea
weblogic installation wizard. unlike other bea wls 9.2 distributions, the
generic installer _does not_ come bundled with the workshop for weblogic
platform ide (wlw). bea does not support wlw on the mac. they don't
support wlw on aix either; aix is the os bea's generic installer is
originally targeted for.
i happen to have a working installation of wls & wlw on my sun
microsystem's sunblade 100 with solaris 9 (installed using bea's
solaris_sparc-specific .bin installer; which _does_ come bundled with the
wlw ide). so, i copied the wlw-related stuff (everything in
$bea_home/workshop92 & everything in $bea_home/common/eclipse) from my
solaris box to the appropriate folders on my mac. btw, java.version=1.5.0
on both my solaris box and my mac.
wlw successfully launches on the solaris box using the bea-supplied
solaris-specific launcher ($WLW_HOME/workshop4WP) and the launcher's
associated co-located .ini file. but there is no launcher for the "hacked"
wlw install on the mac. and obviously the solaris-specific launcher won't
run on a mac. so instead i'm trying to launch wlw on the mac using the
$WLW_HOME/startup.jar:
java -Xms384m \
-Xmx512m -XX:MaxPermSize=256m -DprodMode=production \
-Dcom.bea.workshop=true -Dweblogic.home=/Applications/bea/weblogic92 \
-Dosgi.install.area=/Applications/bea/workshop92/eclipse \
-Dosgi.instance.area.default=/Applications/bea/user_projects /w4WP_workspaces/Untitled
-Dosgi.configuration.area=/Applications/bea/workshop92/works hop4WP/eclipse/configuration
-Declipse.product=com.bea.wlw.product.workshop \
-Declipse.vm=/System/Library/Frameworks/JavaVM.framework/Ver sions/1.5.0/Home/bin/java
-cp $CLASSPATH:$WLW_HOME/startup.jar org.eclipse.core.launcher.Main \
-application org.eclipse.ui.ide.workbench \
-vm
/System/Library/Frameworks/JavaVM.framework/Versions/1.5.0/H ome/bin/java \
-vmargs \
-ea \
-da:org.apache.xbeans... \
-os macos -arch ppc -showsplash 600 \
-launcher $WLW_HOME/startup.jar \
$OSGI_INSTALL_AREA/plugins/com.bea.wlw.product_9.2.1/splash. bmp -exitdata
0 \
-jar $WLW_HOME/startup.jar
that fails with the stacktrace logged to the osgi.configuration.area. my
specific questions are to do with the following lines from the stacktrace
(see bottom of this post for full stacktrace):
Caused by: java.lang.NoClassDefFoundError: org/eclipse/swt/SWTError
Root exception:
Caused by:
java.lang.NoClassDefFoundError:org/eclipse/ui/plugin/Abstrac tUIPlugin
Root exception:
java.lang.NoClassDefFoundError: org/eclipse/ui/plugin/AbstractUIPlugin
java.lang.ClassNotFoundException:
org.eclipse.ui.internal.ide.IDEApplication
Bundle update@plugins/org.eclipse.swt.gtk.solaris.sparc_3.1.1.jar
[429] was not resolved.
in my experience, a NoClassDefFoundError usually suggests that there are 2
or more versions of the reported class somewhere on the classpath. but the
only place i have been able to find org.eclipse.swt.SWTError is in
$OSGI_INSTALL_AREA/plugins/org.eclipse.swt.gtk.solaris.sparc _3.1.1.jar.
and the only place i have been able to find
org.eclipse.ui.plugin.AbstractUIPlugin is in
$OSGI_INSTALL_AREA/plugins/org.eclipse.ui.workbench_3.1.2.ja r. i can see
that org.eclipse.ui.internal.ide.IDEApplication is in
$OSGI_INSTALL_AREA/plugins/org.eclipse.ui.ide_3.1.1.jar. i have added all
three of these jars - plus others - to the classpath. i have set
$CLASSPATH to the following:
/Applications/bea/utils/bsu/wlw-plaf.jar:/Applications/bea/w eblogic92/common/lib/upgrade/wlw-plugin.jar:/Applications/be a/weblogic92/common/lib/wlw-plaf.jar:/Applications/bea/weblo gic92/common/lib/wlw-util.jar:/Applications/bea/weblogic92/j avelin/autoload/wlw-langx.jar:/Applications/bea/weblogic92/s erver/lib/wlw-lang81-COM.jar:/Applications/bea/weblogic92/se rver/lib/wlw-langx.jar:/Applications/bea/weblogic92/server/l ib/wlw-system.jar:/Applications/bea/weblogic92/server/lib/wl w-wsee-soapfault.jar:/Applications/bea/weblogic92/workshop/l ib/wlw-antlib.jar:/Applications/bea/weblogic92/workshop/lib/ wlw-libmodules.jar:/Applications/bea/weblogic92/workshop/lib /wlw-splitsrc.jar:/Applications/bea/weblogic92/workshop/lib/ wlw-util.jar:/Applications/bea/workshop92/eclipse/plugins/or g.eclipse.swt.gtk.solaris.sparc_3.1.1.jar:/Applications/bea/ workshop92/eclipse/plugins/org.eclipse.swt_3.1.0.jar:/Applic ations/bea/workshop92/eclipse/plugins/org.eclipse.ui.workben ch_3.1.2.jar:/Applications/bea/workshop92//eclipse/plugins/o rg.eclipse.ui.ide_3.1.1.jar
NOTE: curiously, even if i omit the above classpath from the startup.jar
command, or even if i set $CLASSPATH to "", i get the same stacktrace.
so my questions at this point are (please, number your answers to
correspond to the specific questions if you can):
1. exactly which classes|jars does startup.jar need in its classpath?
2. what jars might duplicate versions of the above mentioned classes be
in?
3. if NoClassDefFoundError is not due to duplicate class versions, then
what might be causing it?
4. why can't org.eclipse.ui.internal.ide.IDEApplication class be found
when i _know_ it is in
/Applications/bea/workshop92//eclipse/plugins/org.eclipse.ui .ide_3.1.1.jar;
and that jar _is_ in the classpath that is set when i run startup.jar?
5. exactly what command line args should i pass to startup.jar?
6. what do i have to do to have
org.eclipse.swt.gtk.solaris.sparc_3.1.1.jar be successfully resolved?
thanks in advance for your help.
!SESSION 2007-05-05 15:05:35.388
eclipse.buildId=M20060118-1600
java.version=1.5.0_07
java.vendor=Apple Computer, Inc.
BootLoader constants: OS=macosx, ARCH=ppc, WS=gtk, NL=en_US
Framework arguments: -application org.eclipse.ui.ide.workbench
Command-line arguments: -application org.eclipse.ui.ide.workbench
!ENTRY org.eclipse.osgi 2007-05-05 15:05:50.467
!MESSAGE An error occurred while automatically activating bundle
org.eclipse.ui.workbench (280).
!STACK 0
org.osgi.framework.BundleException: The activator
org.eclipse.ui.internal.WorkbenchPlugin for bundle
org.eclipse.ui.workbench is invalid
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:149)
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:965)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:316)
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:264)
org.eclipse.core.runtime.adaptor.EclipseClassLoader.findLoca lClass(EclipseClassLoader.java:116)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:337)
org.eclipse.osgi.framework.internal.core.SingleSourcePackage .loadClass(SingleSourcePackage.java:37)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:386)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:350)
org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. loadClass(AbstractClassLoader.java:78)
at java.lang.ClassLoader.loadClass(ClassLoader.java:251)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:319 )
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:620)
org.eclipse.osgi.framework.adaptor.core.DefaultClassLoader.d efineClass(DefaultClassLoader.java:370)
org.eclipse.core.runtime.adaptor.EclipseClassLoader.defineCl ass(EclipseClassLoader.java:233)
org.eclipse.osgi.framework.adaptor.core.DefaultClassLoader.f indClassImpl(DefaultClassLoader.java:343)
org.eclipse.osgi.framework.adaptor.core.DefaultClassLoader.f indClass(DefaultClassLoader.java:235)
org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. findLocalClass(AbstractClassLoader.java:183)
org.eclipse.core.runtime.adaptor.EclipseClassLoader.basicFin dLocalClass(EclipseClassLoader.java:141)
org.eclipse.core.runtime.adaptor.EclipseClassLoader.findLoca lClass(EclipseClassLoader.java:82)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:389)
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:275)
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:142)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1248)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:152)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:142)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:129)
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 48)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:222)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Class.java:23 28)
at java.lang.Class.getConstructor0(Class.java:2640)
at java.lang.Class.newInstance0(Class.java:321)
at java.lang.Class.newInstance(Class.java:303)
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:144)
... 55 more
Root exception:
!ENTRY org.eclipse.osgi 2007-05-05 15:05:50.543
org.eclipse.ui.ide (273).
!STACK 0
org.eclipse.ui.internal.ide.IDEWorkbenchPlugin for bundle
org.eclipse.ui.ide is invalid
... 27 more
Root exception:
!ENTRY org.eclipse.osgi 2007-05-05 15:05:50.559
!MESSAGE Application error
!STACK 1
org.eclipse.core.runtime.CoreException[1]:
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:405)
!ENTRY org.eclipse.osgi 2007-05-05 15:05:50.598
!MESSAGE Bundle update@plugins/org.eclipse.swt.gtk.solaris.sparc_3.1.1.jar
Re: Workshop for Weblogic Platform 9.2 on Mac OS X 10.4 [message #192140 is a reply to message #192132] Sat, 05 May 2007 15:43 Go to previous messageGo to next message
Eclipse User
i've been able to resolve the exceptions from the first stacktrace i
posted earlier by adding the following to the command line:
-Dosgi.frameworkClassPath=$CLASSPATH \
i have also added the following to the $CLASSPATH"
/Applications/bea/workshop92//eclipse/plugins/org.eclipse.os gi_3.1.2.jar
the above jar contains org.eclipse.core.runtime.adaptor.EclipseStarter:
$ jar -tvf
/Applications/bea/workshop92//eclipse/plugins/org.eclipse.os gi_3.1.2.jar |
grep EclipseStarter
686 Wed Jan 18 17:19:16 GMT 2006
org/eclipse/core/runtime/adaptor/EclipseStarter$1.class
924 Wed Jan 18 17:19:16 GMT 2006
org/eclipse/core/runtime/adaptor/EclipseStarter$2.class
925 Wed Jan 18 17:19:16 GMT 2006
org/eclipse/core/runtime/adaptor/EclipseStarter$3.class
1186 Wed Jan 18 17:19:16 GMT 2006
org/eclipse/core/runtime/adaptor/EclipseStarter$4.class
744 Wed Jan 18 17:19:16 GMT 2006
org/eclipse/core/runtime/adaptor/EclipseStarter$InitialBundl e.class
36233 Wed Jan 18 17:19:16 GMT 2006
org/eclipse/core/runtime/adaptor/EclipseStarter.class
but now attempts to launch wlw fails with:
!SESSION Sat May 05 20:18:01 BST 2007
!ENTRY org.eclipse.core.launcher 4 0 2007-05-05 20:18:02.440
!MESSAGE Exception launching the Eclipse Platform:
!STACK
at java.net.URLClassLoader$1.run(URLClassLoader.java:200)
at java.net.URLClassLoader.findClass(URLClassLoader.java:188)
at java.lang.ClassLoader.loadClass(ClassLoader.java:306)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:331 )
so, my next question is:
7. why can't org.eclipse.core.runtime.adaptor.EclipseStarter class be
found when i _know_ it is
in/Applications/bea/workshop92//eclipse/plugins/org.eclipse. osgi_3.1.2.jar;
Re: Workshop for Weblogic Platform 9.2 on Mac OS X 10.4 [message #192154 is a reply to message #192132] Sun, 06 May 2007 08:03 Go to previous message
Eclipse User
hi again,
i have now resolved most of the issues i originally asked about:
so far, this is the classpath i've set to resolve the first set of
NoClassDefFoundErrors & ClassNotFoundExceptions that i originally posted:
export
CLASSPATH=/Applications/bea/workshop92/eclipse/plugins/org.e clipse.osgi_3.1.2.jar:/Applications/bea/workshop92/eclipse/p lugins/org.eclipse.swt.gtk.solaris.sparc_3.1.1.jar:/Applicat ions/bea/workshop92/eclipse/plugins/org.eclipse.swt_3.1.0.ja r:/Applications/bea/workshop92/eclipse/plugins/org.eclipse.u i.workbench_3.1.2.jar:/Applications/bea/workshop92//eclipse/ plugins/org.eclipse.ui.ide_3.1.1.jar:/Applications/bea/works hop92//eclipse/plugins/org.eclipse.core.runtime_3.1.2.jar:/A pplications/bea/workshop92//eclipse/plugins/org.eclipse.jfac e_3.1.1.jar
in?
i wrote a perl script that trawls my plugin directory and examines all the
jars. it did not find duplicates for SWTError nor AbstractUIPlugin
even though the jars were on the system classpath, as far as the eclipse
framework was concerned, they didn't exist until i added the
"-DframeworkClassPath=$CLASSPATH" property
4 & 7. why can't org.eclipse.ui.internal.ide.IDEApplication |
org.eclipse.core.runtime.adaptor.EclipseStarter class be found...?
see answer to 3
this is the command that i have arrived at for the time being:
java -Xms384m \
-Dosgi.parentClassloader=app \
-Dosgi.framework=/Applications/bea/workshop92/eclipse/plugin s/org.eclipse.osgi_3.1.2.jar
-Dosgi.syspath=/Applications/bea/workshop92/eclipse/plugins \
-cp $CLASSPATH:/Applications/bea/workshop92/workshop4WP/startup. jar
-launcher /Applications/bea/workshop92/workshop4WP/startup.jar \
-framework \
-vm
-nosplash \
-vmargs \
-ea \
-os macos -arch ppc
although i have resolved the first issues with the above classpath changes
and command line changes, i have progressed to a new issue...:
!SESSION 2007-05-06 11:47:19.447
Framework arguments: -application org.eclipse.ui.ide.workbench -framework
-framework
!ENTRY org.eclipse.osgi 2007-05-06 11:47:32.916
!STACK 1
at org.eclipse.ui.internal.Workbench.createDisplay(Workbench.ja va:379)
at org.eclipse.ui.PlatformUI.createDisplay(PlatformUI.java:155)
org.eclipse.ui.internal.ide.IDEApplication.createDisplay(IDE Application.java:128)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:79)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
!ENTRY org.eclipse.osgi 2007-05-06 11:47:32.963
does this ring any bells with anybody? something is obviously missing from
somewhere. any suggestions? and once again:
Previous Topic:setting Tomcat 6 in server selection
Next Topic:Debugging Axis2 Web Service on Tomcat with Eclipse
Current Time: Wed May 22 09:29:21 EDT 2013
Powered by FUDForum. Page generated in 0.09387 seconds
