Home » Eclipse Projects » Web Tools Project (WTP) » error IWAB0398E when creating wsdl from java source
| error IWAB0398E when creating wsdl from java source [message #191391] |
Thu, 12 April 2007 11:21  |
Originally posted by: anders.linden.nomail.xxx
Hello!
This is what I tried (using eclipse 3.2)
new->project->java project
project name: webservicetest (create separate source and output folders)
right click on src, new package, package name: testing.webservices
right click on package, new class, name: webservicetest (ok, its not
capitalized), the
package gets automatically filled in.
exchange of source code to:
package testing.webservices;
import java.rmi.Remote;
public interface webservicetest extends Remote
public String kryptera(String value);
public String dekryptera(String value);
right click on package, new class, name: webservicetestimpl (ok, not
capitalized either).
public class webservicetestimpl implements webservicetest
public webservicetestimpl()
return "aaa";
return "bbb";
saving
now, I tried to create a webservice
right clicking on my first project and new->other->Web Services->Web Service
in the following dialog, I put a name of a Service implmentation, however,
some time before when I have tried the same thing, the box is pre-filled.
For some reason its not now. (why not any longer?)
I click on the browse button and all I have to put there is the class name
without package prefix and pressing return. Then the prefix goes there
automatically.
the web service type is bottom up.
I try next here.
After some progress indication, I get the names of my two methods, kryptera
and dekryptera.
the boxes are checked, I leave it that way.
when I click next here (or finish), I get the following error message:
IWAB0398E Error in generating WSDL from Java:
java.lang.ClassNotFoundException: testing.webservices.webservicetestimpl
question: why?
The class was found one time (my method names were detected) but not the
other time.
So is eclipse incompatible with itself?
I have tried to change the language compliance of webservicetest to 1.4. (I
need to do that anyway before I deploy the project, I presume, jboss doesnt
want a newer version).
In the service project itself, I never get the opportunity to set language
compliance, but its not a java project after all.
details for the error follows futher down:
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:402)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:347)
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
org.apache.tools.ant.AntClassLoader.findBaseClass(AntClassLo ader.java:1197)
org.apache.tools.ant.AntClassLoader.loadClass(AntClassLoader .java:990)
at org.apache.axis.utils.ClassUtils$2.run(ClassUtils.java:187)
at org.apache.axis.utils.ClassUtils.loadClass(ClassUtils.java:1 60)
at org.apache.axis.utils.ClassUtils.forName(ClassUtils.java:100 )
at org.apache.axis.wsdl.fromJava.Emitter.setCls(Emitter.java:20 79)
org.apache.axis.tools.ant.wsdl.Java2WsdlAntTask.execute(Java 2WsdlAntTask.java:188)
org.eclipse.jst.ws.internal.axis.consumption.core.command.Ja va2WSDLCommand.executeAntTask(Java2WSDLCommand.java:179)
org.eclipse.jst.ws.internal.axis.consumption.core.command.Ja va2WSDLCommand.execute(Java2WSDLCommand.java:94)
org.eclipse.jst.ws.internal.axis.creation.ui.command.BUCodeG enOperation$BottomUpWSModifyOperation.execute(BUCodeGenOpera tion.java:116)
org.eclipse.jst.ws.internal.axis.creation.ui.command.BUCodeG enOperation.execute(BUCodeGenOperation.java:80)
org.eclipse.wst.command.internal.env.core.fragment.CommandFr agmentEngine.runCommand(CommandFragmentEngine.java:414)
org.eclipse.wst.command.internal.env.core.fragment.CommandFr agmentEngine.visitTop(CommandFragmentEngine.java:354)
org.eclipse.wst.command.internal.env.core.fragment.CommandFr agmentEngine.moveForwardToNextStop(CommandFragmentEngine.jav a:252)
org.eclipse.wst.command.internal.env.ui.widgets.SimpleComman dEngineManager$5.run(SimpleCommandEngineManager.java:250)
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:369)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:313)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 851)
org.eclipse.wst.command.internal.env.ui.widgets.SimpleComman dEngineManager.runForwardToNextStop(SimpleCommandEngineManag er.java:220)
org.eclipse.wst.command.internal.env.ui.widgets.WizardPageMa nager.runForwardToNextStop(WizardPageManager.java:94)
org.eclipse.wst.command.internal.env.ui.widgets.WizardPageMa nager.getNextPage(WizardPageManager.java:145)
org.eclipse.wst.command.internal.env.ui.widgets.SimpleWizard Page.getNextPage(SimpleWizardPage.java:136)
org.eclipse.jface.wizard.WizardDialog.nextPressed(WizardDial og.java:751)
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:351)
at org.eclipse.jface.dialogs.Dialog$3.widgetSelected(Dialog.jav a:660)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:90)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:928)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3348)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2968)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:820 )
at org.eclipse.jface.window.Window.open(Window.java:796)
at org.eclipse.ui.actions.NewWizardAction.run(NewWizardAction.j ava:181)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:499 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:539)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1930)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1894)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:422)
org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
| Re: error IWAB0398E when creating wsdl from java source [message #191403 is a reply to message #191391] |
Fri, 13 April 2007 03:43   |
Mirza Hadzic Messages: 19 Registered: July 2009 |
Junior Member |
I have the same issue. Next button shows message IWAB0398E, but when I
press the "Next" again, IWAB0398E message is *not* repeated and service
is created. Weird. (Calisto, WST 1.5.3)
Mirza
Anders Lindén wrote:
> Hello!
> capitalized), the
> return "aaa";
> return "bbb";
> saving
> automatically.
> I try next here.
> and dekryptera.
> question: why?
> other time.
> at
> at
> at
> at java.lang.ClassLoader.loadClass(Unknown Source)
> at
> at
> at java.security.AccessController.doPrivileged(Native Method)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
| Re: error IWAB0398E when creating wsdl from java source [message #191420 is a reply to message #191410] |
Fri, 13 April 2007 06:08   |
Junior Member |
> Hm, I get the error message all the time.
> Do you get a wsdl-file btw?
yes.
> /Anders
> "mirza" <mirza@seznam.cz> wrote in message
> news:evnc6p$u6t$1@build.eclipse.org...
>> press the "Next" again, IWAB0398E message is *not* repeated and service is
>> Mirza
>>> Hello!
>>> capitalized), the
>>> return "aaa";
>>> return "bbb";
>>> saving
>>> Service
>>> however, some time before when I have tried the same thing, the box is
>>> pre-filled. For some reason its not now. (why not any longer?)
>>> name without package prefix and pressing return. Then the prefix goes
>>> there automatically.
>>> I try next here.
>>> kryptera and dekryptera.
>>> question: why?
>>> other time.
>>> (I need to do that anyway before I deploy the project, I presume, jboss
>>> doesnt want a newer version).
>>> language compliance, but its not a java project after all.
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
| Re: error IWAB0398E when creating wsdl from java source [message #191445 is a reply to message #191420] |
Fri, 13 April 2007 16:11   |
Kathy Chan Messages: 93 Registered: July 2009 |
Member |
Hi Andes,
I tried creating bottom-up Web services using webservicetest and
webservicetestimpl using both WTP 1.5.3 and WTP 2.0 M6. If I just select
the the project, the service implementation class is not filled in. That's
working as expected since the initial selection is a project, not the Java
file. I don't think we have a release that pre-fill service implementation
if the initial selection is just a project. If however you had select the
Java file and then bring up the Web service wizard, then the service
implementation field is filled in.
Anyways, I just select project, bring up the Web service wizard, then use
the Browse button to browse for the webservicetestimpl class. I was then
able to see the 2 methods listed and the wizard was able to complete
successfully. I was also able to invoke the Web service using the Web
Services Explorer and sample JSP.
If you still run into this problem with WTP 1.5.3/1.5.4 or WTP 2.0 M6,
please open a defect in bugzilla. If you do run into the problem, could you
please check to see if the .class file exist (change to resource view and
check the Java output directory which is defaulted to build/classes
directory)? The org.apache.axis.tools.ant.wsdl.Java2WsdlAntTask needs to be
able to load the class in order to process it. In some interim driver in
earlier releases, I've seen similar ClassNotFound problem. That's when I
found that the .class files did not get generated in that project. Cleaning
the project solved that problem. However, I have not seen that problem in
released driver lately.
Kathy Chan
news:evnkmu$g3c$1@build.eclipse.org...
> yes.
>> /Anders
>>> Mirza
>>> Anders Lind
| Re: error IWAB0398E when creating wsdl from java source [message #191477 is a reply to message #191445] |
Sat, 14 April 2007 09:03   |
Thanks for your reply Kathy!
I downloaded wtp WTP 2.0 M6 and extracted it on top of my eclipse directory.
Then I created a java project, added the package, added the two classes.
I put the source code in them. Separate src and output folders.
I right clicked webservicetestimpl.java and new->other->Web Services and now
I could not any longer pick the choice web service because it was not there
any longer.
The only two alternatives were "ant files" and "wsdl".
I tried wsdl and named the wsdl webservicetest.wsdl.
I created a skeleton, using soap and document literal (for some reason,
there is no hint of any kind what those alternatives represent), I clicked
finish and there my wsdl is.
But none of the java methods are automatically put in it (checking with a
text editor), and when I click the new tab "WSDL Editor", nothing happens.
That tab does not change the contents in the area where the code window is,
so if I look at the class webservicetest.java and then I click the WSDL
Editor tab, the code window is still displaying the contents of
webservicetest.java.
Altering the code some does not affect the contents of the wsdl file.
So the newer version of wtp wasnt exactly the best one, if we look on how
far we came in the progress. :)
"Kathy Chan" <kathy@ca.ibm.com> wrote in message
news:evoo4v$710$1@build.eclipse.org...
> Hi Andes,
> That's working as expected since the initial selection is a project, not
> the Java file. I don't think we have a release that pre-fill service
> implementation if the initial selection is just a project. If however you
> had select the Java file and then bring up the Web service wizard, then
> the service implementation field is filled in.
> you please check to see if the .class file exist (change to resource view
> and check the Java output directory which is defaulted to build/classes
> be able to load the class in order to process it. In some interim driver
> in earlier releases, I've seen similar ClassNotFound problem. That's when
> I found that the .class files did not get generated in that project.
> Cleaning the project solved that problem. However, I have not seen that
> problem in released driver lately.
> Kathy Chan
>> yes.
>>> /Anders
>>>> Mirza
>>>> Anders Lind
| Re: error IWAB0398E when creating wsdl from java source [message #191485 is a reply to message #191445] |
Sat, 14 April 2007 12:28   |
I have tried now with a fresh eclipse and wtp from:
http://download.eclipse.org/webtools/downloads/drops/R2.0/I- I200704122344-200704122344/
I downloaded eclipse, emf-sdo-xsd, GEF-SDK, dtp-sdk and wtp.
I extracted all those into the same directory.
I can create a web service and get the same error...
> Hi Andes,
> Kathy Chan
>> yes.
>>> /Anders
>>>> Mirza
>>>> Anders Lind
Current Time: Sat May 18 17:19:07 EDT 2013
Powered by FUDForum. Page generated in 0.01937 seconds
