Home » Eclipse Projects » Web Tools Project (WTP) » JFaceNodeAdapter questions
JFaceNodeAdapter questions [message #190516] Wed, 28 March 2007 01:10 Go to next message
Eclipse User
Originally posted by: konigsberg.at.geemail.dot.com
1. What is the difference between IJFaceNodeAdapter.getElements and
IJFaceNodeAdapter.getChildren()? I'm not clear on this.
2. If I have XML like so:
<foo>
<bar val=1/>
<bar val=2/>
<quux val=3/>
<quux val=4/>
</foo>
And I want the outline to look like this:
Foo
+-bars
+-bar val=1
-bar val=2
+-quuxes
+-quux val=3
-quux val=4
I imagine I can play with getChildren and getElements to create a fake
sub-heirarchy. I can imagine that there may be some problems with this,
such as with the double-click listener and so on. Am I looking to do
something abominable, or is this somewhat standard? Thanks!
Thanks, Robert
Re: JFaceNodeAdapter questions [message #190571 is a reply to message #190516] Wed, 28 March 2007 13:46 Go to previous messageGo to next message
Nitin Dahyabhai is currently offline Nitin Dahyabhai
Robert Konigsberg wrote:
> Hello,
> <foo>
> <bar val=1/>
> <bar val=2/>
> <quux val=3/>
> <quux val=4/>
> </foo>
> Foo
> +-bars
> +-bar val=1
> -bar val=2
> +-quuxes
> +-quux val=3
> -quux val=4
1. The differences are documented in the method documentation in the
IStructuredContentProvider and ITreeContentProvider interfaces.
2. I wouldn't expect any problems with double-click as its only
implemented for known object types. If you do run across any
problems, just open a bug report. As for faking the tree hierarchy,
the DTD outline already does something similar for its "Group items
logically" mode, so it's not "abominable" at all.
Nitin Dahyabhai
Structured Source Editor
Nitin Dahyabhai
Eclipse WTP, IBM
Re: JFaceNodeAdapter questions [message #190631 is a reply to message #190571] Wed, 28 March 2007 17:29 Go to previous message
Eclipse User
>> Hello,
>> <foo>
>> <bar val=1/>
>> <bar val=2/>
>> <quux val=3/>
>> <quux val=4/>
>> </foo>
>> Foo
>> +-bars
>> +-bar val=1
>> -bar val=2
>> +-quuxes
>> +-quux val=3
>> -quux val=4
>> this, such as with the double-click listener and so on. Am I looking
>> to do something abominable, or is this somewhat standard? Thanks!
Sorry, I didn't look that far down the interface chain. Thanks.
> implemented for known object types. If you do run across any problems,
> just open a bug report. As for faking the tree hierarchy, the DTD
> outline already does something similar for its "Group items logically"
Awesome, thanks. Nitin comes to the rescue, again.
> Nitin Dahyabhai
Previous Topic:BEA WebLogic Server support in WTP 2.0
Next Topic:Accessing an SSL website within Web Services Explorer
Current Time: Sun May 19 14:34:33 EDT 2013
Powered by FUDForum. Page generated in 0.01522 seconds
