Home » Eclipse Projects » Web Tools Project (WTP) » No editor descriptor for id
No editor descriptor for id [message #190547] Wed, 28 March 2007 10:53 Go to next message
Pierre-Henry Perret is currently offline Pierre-Henry Perret
Member
I have installed wtp and when I edit an xml file it logs the followings
org.eclipse.ui.PartInitException: No editor descriptor for id
org.eclipse.wst.xml.ui.internal.tabletree.XMLMultiPageEditor Part
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:541)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2485)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:170)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
What is the orirgin of this problem?
Re: No editor descriptor for id [message #190563 is a reply to message #190547] Wed, 28 March 2007 13:37 Go to previous message
Nitin Dahyabhai is currently offline Nitin Dahyabhai
> messages:
Could you be missing a prerequisite such as JEM or EMF?
Nitin Dahyabhai
Structured Source Editor
Nitin Dahyabhai
Eclipse WTP, IBM
Previous Topic:JSP validation and Struts tags
Next Topic:BEA WebLogic Server support in WTP 2.0
Current Time: Fri May 24 09:57:02 EDT 2013
Powered by FUDForum. Page generated in 0.02805 seconds
