Home » Eclipse Projects » Web Tools Project (WTP) » Using getParameterMap() with Tomcat 4.1
Using getParameterMap() with Tomcat 4.1 [message #188930] Thu, 01 March 2007 18:04 Go to next message
Eclipse User
Originally posted by: sharper3.austin.dot.rr.dot.com
I have a servlet with a doPost method that retrieves the parameter set with
the HttpServletRequest.getParameterMap() method. This seems to work ok, until
I try to make any manipulations to the map, e.g. the map.remove(Object key)
method.
Apparently, because I am running in Tomcat 4.1, the above call actually
returns an org.apache.catalina.util.ParameterMap object, which has added
locking (see
http://tomcat.apache.org/tomcat-4.
0-doc/catalina/docs/api/org/apache/catalina/util/ParameterMa p.html).
This bothers me a little, because it might tie my implementation to the Tomcat
platform. But I could probably live with it, temporarily anyway.
However, I can't actually use that object because the default set of Tomcat
4.1 libraries in my project don't include it. I tried manually adding
${CATALINA_HOME}\server\libs\catalina.jar to my project. That works to
resolve the compile time issue, but at run time I still can't find the class.
I've tried copying the ParameterMap to another Map object (HashMap) that I can
manipulate with the remove method, but it still seems to think it is a
ParameterMap.
Does anyone have any suggestions or pointers?
scott
Re: Using getParameterMap() with Tomcat 4.1 [message #189017 is a reply to message #188930] Fri, 02 March 2007 15:00 Go to previous message
Larry Isaacs is currently offline Larry Isaacs
The servlet spec says getParameterMap returns an immutable Map, so
modification of that map is not allowed. It's not clear what "it" was
that still thought it was a ParameterMap after copying, so I can't say
what the copy problem might be.
Larry
> method.
> locking (see
> ParameterMap.
> scott
Previous Topic:Random hangs with WTP 1.5.3
Next Topic:JSP validator - Undefined attribute name
Current Time: Fri May 24 21:18:49 EDT 2013
Powered by FUDForum. Page generated in 0.02093 seconds
