Home » Eclipse Projects » Web Tools Project (WTP) » out of sync using a vfat filesystem?
out of sync using a vfat filesystem? [message #188047] Thu, 15 February 2007 09:47 Go to next message
Eclipse User
Originally posted by: fluca1978.infinito.it
Hi all,
I'm using the webtools on my workspace that is stored on a vfat partition
(I'm running ubuntu 6.10, eclipse 3.2, jdk 1.6). The problem I'm
experiencing, that I don't have with other Java projects (not web related)
is that after the environment has shut down and restart again it always
says me that my project is out of sync. Or better, when I try to perform a
refactoring I got an out of sync on everything (even the server!) and even
performing a refresh does not solve the problem. Now I guess it could be an
issue related to the vfat filesystem since after a refresh I can see in the
package explorer two folders web-inf, once lower case (that is the original
one) and one up case, the latter containing a file web.xml that does not
point to my servlet. Of course, when I try to run the servlet I got an
error saying the servlet is unavailble and moreover it tries to execute the
full qualified name of the servlet instead of the name providen in the
original web.xml file.
Anyone knows a way to fix this annoying behaviour?
Luca
Re: out of sync using a vfat filesystem? [message #188104 is a reply to message #188047] Fri, 16 February 2007 06:54 Go to previous messageGo to next message
Eclipse User
Luca,
I'm not sure what might cause this but I wonder if it is possible that
you created a resource in the workspace with a name that's not exactly
the same as the actual case of that name in the file system?
Luca Ferrari wrote:
> Hi all,
> Luca
Re: out of sync using a vfat filesystem? [message #188285 is a reply to message #188104] Tue, 20 February 2007 05:13 Go to previous messageGo to next message
Eclipse User
Ed Merks wrote:
> Luca,
I guess it is the problem, since when things goes bad I can see a folder
web-inf and one WEB-INF in the project explorer. However, if I try to enter
in the WEB-INF or web-inf folder I got the same result (from the shell) and
there's only one folder stored on the disk. The content of the two folders
in the project explorer is however different.
Moreover I didn't experienced this problem before using the same eclipse
settings.
Any idea?
Luca
Re: out of sync using a vfat filesystem? [message #188292 is a reply to message #188285] Tue, 20 February 2007 06:13 Go to previous message
Eclipse User
--------------020502080602090807090104
Luca,
Probably it's best to remove the folder completely from the file system
and see which case version WTP wants to create to replace it and then
stick with that way of spelling it.
Luca Ferrari wrote:
> Ed Merks wrote:
>> Luca,
> settings.
> Any idea?
> Luca
<html>
<head>
</head>
Luca,<br>
<br>
stick with that way of spelling it. <br>
<br>
<br>
Luca Ferrari wrote:
<blockquote cite="miderehl1$vg6$1@utils.eclipse.org" type="cite">
<pre wrap="">Ed Merks wrote:
</pre>
<blockquote type="cite">
<pre wrap="">Luca,
</pre>
</blockquote>
<pre wrap=""><!---->
settings.
Any idea?
Luca
</pre>
</blockquote>
<br>
</body>
</html>
--------------020502080602090807090104--
Previous Topic:Deploying EJBs to Weblogic
Next Topic:Creating an XML Document (and more) from an InputStream?
Current Time: Thu May 23 23:49:20 EDT 2013
Powered by FUDForum. Page generated in 0.02203 seconds
