Home » Eclipse Projects » Web Tools Project (WTP) » problems with Axis deployment
problems with Axis deployment [message #188056] Thu, 15 February 2007 10:49
Dan Morrow is currently offline Dan Morrow
I've built a SOAP WebService, using the WTP tools in Eclipse.
I created a WSDL, created operations, and generated the Java source code.
I can run the project just fine in Eclipse. When running and debugging
under Eclipse, everything works, and I can have other machines in my
network send SOAP calls to mine, and I can debug it, and it's all good.
Now, I just need to deploy this stuff onto a server running Tomcat/Axis.
My question is, what is the best way to do this? Ideally, what I'd
really like to do is just create a JAR and drop it into a directory in
Axis, and have it "just work." But, according to the docs, I need to run
the AdminService against my "deploy.wsdd" file. Is there a way I can
package up all of my java classes, into one container (a JAR) along with
the "deploy.wsdd" file, and have Axis do the right thing?
If that can't be done, fine. I guess I'm wondering what the best steps
are in taking a web-service generated by Eclipse Web Tools, and getting
them to Axis. I'm new to Eclipse and Axis, so I'm having some trouble
with the basics.
Any advice would be greatly appreciated,
-Dan.
Previous Topic:XML Editor - wrong formatting of mixed content types
Next Topic:Extending JSP Editor
Current Time: Fri May 24 23:06:40 EDT 2013
Powered by FUDForum. Page generated in 0.01497 seconds
