| Mozilla Perspective is broken [message #183113] |
Wed, 22 November 2006 15:03  |
Originally posted by: farcaller.gmail.com
Hi all,
When I try to open Mozilla Perspective and navigate to any page I get:
Error opening Mozilla Browser!
Reason:
Error opening Mozilla Browser... EditorPart did not initialize properly!
Backtrace:
org.eclipse.atf.mozilla.ide.core.MozillaInitializationExcept ion
org.eclipse.atf.mozilla.ide.core.MozillaHelper.getMozillaIns tance(MozillaHelper.java:51)
org.eclipse.atf.mozilla.ide.ui.browser.MozBrowserEditor.init (MozBrowserEditor.java:192)
at org.eclipse.ui.internal.EditorManager.createSite(EditorManag er.java:840)
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:583)
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:372)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:566)
org.eclipse.ui.internal.EditorReference.getEditor(EditorRefe rence.java:214)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2595)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2528)
at org.eclipse.ui.internal.WorkbenchPage.access$10(WorkbenchPag e.java:2520)
at org.eclipse.ui.internal.WorkbenchPage$9.run(WorkbenchPage.ja va:2505)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2500)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2477)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:290)
org.eclipse.atf.mozilla.ide.ui.browser.util.MozBrowserUtil.o penMozillaBrowser(MozBrowserUtil.java:40)
org.eclipse.atf.mozilla.ide.ui.browser.OpenMozBrowserEditorA ction.run(OpenMozBrowserEditorAction.java:57)
org.eclipse.atf.mozilla.ide.ui.browser.OpenMozBrowserEditorA ction.run(OpenMozBrowserEditorAction.java:85)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:254)
org.eclipse.ui.internal.WWinPluginAction.runWithEvent(WWinPl uginAction.java:229)
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:539)
at org.eclipse.jface.action.ActionContributionItem.access$
(ActionContributionItem.java:488)
org.eclipse.jface.action.ActionContributionItem$6.handleEven t(ActionContributionItem.java:441)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1085)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3166)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2842)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1914)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
SWT Browser works in eclipse correctly (via XULRunner 1.8.0.4), I have
latest versions of Eclipse and Webtools installed.
Any ideas?
Sincerely,
Vladimir "Farcaller" Pouzanov
http://hackndev.com
| Re: Mozilla Perspective is broken [message #183217 is a reply to message #183113] |
Fri, 24 November 2006 16:20  |
Originally posted by: eclipse4.rizzoweb.com
Vladimir "Farcaller" Pouzanov wrote:
> Hi all,
You probably want to post this to the eclipse.webtools.atf group to get
more response.
Hope this helps,
Eric
FUDForum. Page generated in 0.01656 seconds
