| Re: Web tools - cannot update eclipse via update manager - File not found [message #182651 is a reply to message #182547] |
Tue, 14 November 2006 03:17   |
Originally posted by: jelka.kosir.atol.si
David Williams wrote:
> Oh, and I did mean to ask ... just because I'm curious ... why are you
> still using
> Eclipse 3.1? ... if you don't mind me asking.
I am glad you responded and I dont mind answering.
I had a vmware image with environment that was set up some time ago, I
needed to make a demo or better "proof of concept" for a project using
Apache FOP with Domino 6. Domino 6 has quite unique jvm based on java 1.3
(but just slightly different, they say) so I must be able to have
compliance with java 1.3 and I had that all prepared in that image
(although it is possible that we will use Domino 7 with java 1.4, the
project managers are still deciding).
It was just that I wanted to quickly see if things would run together.
I tend to get a bit lost when it comes to JDK's, ... JRE's, ... SDK's and
so on, I'm never sure what I need to install. You are welcome to ask
additionally whatever you think is puzzling, because now that the project
is starting for real, I would like to install latest versions so I would
be able to use all the latest plug-ins available. The only problem is I am
not so familiar with Eclipse and Java development, so I would really need
some guidance on how to setup my development environment.
Mainly these past years I've used Eclipse with php plug-in for development
in php.
Thank you for responding
Jelka
FUDForum. Page generated in 0.09482 seconds
