| WSDL user group [message #181688] |
Tue, 17 October 2006 12:09  |
Originally posted by: spruitt.exstream.com
Can someone recommend a WSDL user / mailing group? I can't seem to locate
one by searching.
I'm have WSDL validation errors I don't understand and I am looking for an
appropriate list to gather some advice.
Thanks.
-S
| Re: WSDL user group [message #181690 is a reply to message #181688] |
Tue, 17 October 2006 14:56   |
Originally posted by: valentinbaciu.hotmail.com
Steve, if they are WSDL validation errors generated by the WST WSDL
validator you can post to this list.
Valentin
"Steve Pruitt" <spruitt@exstream.com> wrote in message
news:eh2v7l$kco$1@utils.eclipse.org...
> one by searching.
> Thanks.
> -S
| Re: WSDL user group [message #181695 is a reply to message #181690] |
Tue, 17 October 2006 15:43   |
Ok.
The service is document literal and it has a multipart response. A chunk of
xml and then a binary file. The relevant wsdl part looks like:
xmlns:mime="http://schemas.xmlsoap.org/wsdl/mime/"
<output>
<mime:multipartRelated>
<mime:part name="headers">
<soap:body use="literal"/>
</mime:part>
<mime:part name="preview">
<mime:content part="Content" type="text/binary"/>
</mime:part>
</mime:multipartRelated>
</output>
The validator is complaining about the tag- <soap:body use="literal"/>
Looking at the mime schema, it specifies children of mime:part must be
namespaced with ##targetNamespace. Don't know how to manage that. Why
require the parent tag namespace? Funny thing, searching around on the web,
I found several sites with examples like:
</mime:part>
So, I can't tell what is going on.
-S
"Valentin Baciu" <valentinbaciu@hotmail.com> wrote in message
news:eh391q$kf3$1@utils.eclipse.org...
Valentin
> one by searching.
> Thanks.
> -S
| Re: WSDL user group [message #181700 is a reply to message #181695] |
Tue, 17 October 2006 17:37   |
Steve, please post the simplest sample WSDL causing the validation error as
well as the exact wording of the validation message. Also, please don't
forget the version of WTP you are using.
We'll take it from there.
Valentin
news:eh3bpo$nac$1@utils.eclipse.org...
> Ok.
> of
> <output>
> </mime:part>
> </mime:part>
> </output>
> web,
> </mime:part>
> -S
> Valentin
>> locate
>> one by searching.
>> an
>> Thanks.
>> -S
| Re: WSDL user group [message #181716 is a reply to message #181700] |
Wed, 18 October 2006 08:23   |
Sorry, Valentin. I thought the bare minimum would be enough. The versions
are Eclipse 3.2.1 and the WTP is 1.5.1-200609230508.
The error message is:
Severity and Description Path Resource Location Creation Time Id
cvc-complex-type.2.4.a: Invalid content was found starting with element
'soap:body'. One of '{WC["http://schemas.xmlsoap.org/wsdl/mime/"]}' is
expected. EWS-WSDL/src EngineServices.wsdl line 66 1161118698302 266
and, finally the full wsdl:
<definitions xmlns="http://schemas.xmlsoap.org/wsdl/"
xmlns:soap="http://schemas.xmlsoap.org/wsdl/soap/"
xmlns:xsd="http://www.w3.org/2001/XMLSchema"
xmlns:soapenc="http://schemas.xmlsoap.org/soap/encoding/"
xmlns:exst="urn:beta-services" targetNamespace="urn:beta-services">
<types>
<xsd:schema>
<xsd:element name="PreviewRequest">
<xsd:complexType>
<xsd:sequence>
<xsd:element name="PubFile" type="xsd:string" maxOccurs="1"
minOccurs="1"/>
<xsd:element name="Driver" maxOccurs="1" minOccurs="1">
<xsd:complexType>
<xsd:sequence>
<xsd:any namespace="##local" processContents="skip"
maxOccurs="unbounded" minOccurs="0"/>
</xsd:sequence>
<xsd:attribute name="filename" type="xsd:string" use="optional"
default="INPUT"/>
</xsd:complexType>
</xsd:element>
</xsd:sequence>
<xsd:attribute name="includeheader" type="xsd:boolean" use="optional"
default="false"/>
</xsd:complexType>
</xsd:element>
<xsd:element name="PreviewResponse">
<xsd:complexType>
<xsd:sequence>
<xsd:element name="PreviewHeaders">
<xsd:complexType>
<xsd:sequence>
<xsd:element name="Version" type="xsd:integer" maxOccurs="1"
minOccurs="0"/>
<xsd:element name="PDL" type="xsd:integer" maxOccurs="1"
minOccurs="0"/>
<xsd:element name="OutputLength" type="xsd:integer" maxOccurs="1"
minOccurs="0"/>
<xsd:element name="MessageLength" type="xsd:integer" maxOccurs="1"
minOccurs="0"/>
<xsd:element name="UserDataLength" type="xsd:integer" maxOccurs="1"
minOccurs="0"/>
<xsd:element name="PageCount" type="xsd:integer" maxOccurs="1"
minOccurs="0"/>
<xsd:element name="ReturnCode" type="xsd:integer" maxOccurs="1"
minOccurs="0"/>
<xsd:element name="FileType" type="xsd:string" maxOccurs="1"
minOccurs="0"/>
</xsd:sequence>
</xsd:complexType>
</xsd:element>
</xsd:sequence>
</xsd:complexType>
</xsd:element>
</xsd:schema>
</types>
<message name="getPreviewRequest">
<part name="Document" element="exst:PreviewRequest"/>
</message>
<message name="getPreviewResponse">
<part name="Document" element="exst:PreviewResponse"/>
<part name="Content" type="xsd:base64Binary"/>
</message>
<portType name="PreviewReportPortType">
<operation name="compose">
<input name="PreviewRequest" message="exst:getPreviewRequest"/>
<output name="PreviewResponse" message="exst:getPreviewResponse"/>
</operation>
</portType>
<binding name="PreviewReportBinding" type="exst:PreviewReportPortType">
<soap:binding transport="http://schemas.xmlsoap.org/soap/http"
style="document"/>
<soap:operation soapAction="urn:beta-service"/>
<input>
</input>
<output>
</mime:part>
</mime:part>
</output>
</operation>
</binding>
<service name="EngineService">
<port name="EngineServicePort" binding="exst:PreviewReportBinding">
<soap:address
location="http://localhost:9080/beta/services/EngineService"/>
</port>
</service>
</definitions>
| Re: WSDL user group [message #181719 is a reply to message #181716] |
Wed, 18 October 2006 10:12   |
Thanks for the sample and details Steve - they did help me find the cause.
It appears the WSDL validator is "correct" based on the MIME binding schema
it has. Problem is that schema is wrong.
The WS-I Attachements Profile has corrected this schema. See
http://www.ws-i.org/Profiles/AttachmentsProfile-1.0.html#MIM E_Binding_Schema_Fixes
I've opened https://bugs.eclipse.org/bugs/show_bug.cgi?id=161410 to track
this issue. Feel free to add yourself as CC to the bug if you have a
bugzilla account.
Regards, Valentin
news:eh56bo$6rt$1@utils.eclipse.org...
> versions
> <types>
> <xsd:schema>
> <xsd:complexType>
> <xsd:sequence>
> minOccurs="1"/>
> <xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> default="INPUT"/>
> </xsd:complexType>
> </xsd:element>
> </xsd:sequence>
> default="false"/>
> </xsd:complexType>
> </xsd:element>
> <xsd:complexType>
> <xsd:sequence>
> <xsd:complexType>
> <xsd:sequence>
> minOccurs="0"/>
> minOccurs="0"/>
> minOccurs="0"/>
> minOccurs="0"/>
> maxOccurs="1"
> minOccurs="0"/>
> minOccurs="0"/>
> minOccurs="0"/>
> minOccurs="0"/>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:element>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:element>
> </xsd:schema>
> </types>
> </message>
> </message>
> </operation>
> </portType>
> style="document"/>
> <input>
> </input>
> <output>
> </mime:part>
> </mime:part>
> </output>
> </operation>
> </binding>
> <soap:address
> </port>
> </service>
> </definitions>
| Re: WSDL user group [message #182088 is a reply to message #181719] |
Thu, 02 November 2006 12:59   |
Thanks for your help. I have been on the road for a bit, so I am late
getting back to you. Looking at the comments in the defect to track it, it
looks like a fix is not coming anytime soon.
I am not sure how I can resolve until a fix shows up. I look at the
validator preference properties and nothing jumped out at me. Can I
directly import the updated schema into my wsdl?
-S
news:eh5cni$imd$1@utils.eclipse.org...
bugzilla account.
Regards, Valentin
> versions
> <types>
> <xsd:schema>
> <xsd:complexType>
> <xsd:sequence>
> minOccurs="1"/>
> <xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> default="INPUT"/>
> </xsd:complexType>
> </xsd:element>
> </xsd:sequence>
> default="false"/>
> </xsd:complexType>
> </xsd:element>
> <xsd:complexType>
> <xsd:sequence>
> <xsd:complexType>
> <xsd:sequence>
> minOccurs="0"/>
> minOccurs="0"/>
> minOccurs="0"/>
> minOccurs="0"/>
> maxOccurs="1"
> minOccurs="0"/>
> minOccurs="0"/>
> minOccurs="0"/>
> minOccurs="0"/>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:element>
> </xsd:sequence>
> </xsd:complexType>
> </xsd:element>
> </xsd:schema>
> </types>
> </message>
> </message>
> </operation>
> </portType>
> style="document"/>
> <input>
> </input>
> <output>
> </mime:part>
> </mime:part>
> </output>
> </operation>
> </binding>
> <soap:address
> </port>
> </service>
> </definitions>
| Re: WSDL user group [message #182096 is a reply to message #182088] |
Thu, 02 November 2006 15:55  |
Steve, here's a suggested workaround.
The broken MIME schema is contributed to the XML catalog by the org.wsdl4j
plug-in. You should be able to override it by specifying a user catalog
entry pointing to the new schema. So download the new schema from the URL I
mentioned below then go to Preferences/Web and XML/XML Catalog, select the
User Specified Entries and click Add. In the dialog browse to the location
where you placed the downloaded schema, specify namespace name as the key
and enter the proper namespace in the namespace field. Click OK and save the
preferences and you should be all set. Try re-validating your file: the
error should go away. I've attached a picture showing the end result of
adding the new schema to the catalog.
Valentin
news:eidblg$c2g$1@utils.eclipse.org...
> it
> -S
> schema
> bugzilla account.
> Regards, Valentin
>> versions
>> <?xml version="1.0" encoding="UTF-8"?>
>> <types>
>> <xsd:schema>
>> <xsd:complexType>
>> <xsd:sequence>
>> minOccurs="1"/>
>> <xsd:complexType>
>> <xsd:sequence>
>> </xsd:sequence>
>> use="optional"
>> default="INPUT"/>
>> </xsd:complexType>
>> </xsd:element>
>> </xsd:sequence>
>> default="false"/>
>> </xsd:complexType>
>> </xsd:element>
>> <xsd:complexType>
>> <xsd:sequence>
>> <xsd:complexType>
>> <xsd:sequence>
>> minOccurs="0"/>
>> minOccurs="0"/>
>> minOccurs="0"/>
>> maxOccurs="1"
>> minOccurs="0"/>
>> maxOccurs="1"
>> minOccurs="0"/>
>> minOccurs="0"/>
>> minOccurs="0"/>
>> minOccurs="0"/>
>> </xsd:sequence>
>> </xsd:complexType>
>> </xsd:element>
>> </xsd:sequence>
>> </xsd:complexType>
>> </xsd:element>
>> </xsd:schema>
>> </types>
>> </message>
>> </message>
>> </operation>
>> </portType>
>> style="document"/>
>> <input>
>> </input>
>> <output>
>> </mime:part>
>> </mime:part>
>> </output>
>> </operation>
>> </binding>
>> <soap:address
>> </port>
>> </service>
>> </definitions>
Attachment: pic.JPG
(Size: 53.30KB, Downloaded 28 times)
FUDForum. Page generated in 0.02438 seconds
