Home » Eclipse Projects » Web Tools Project (WTP) » Re: EMF Model Synchrinization with Multipage Editor (Tree based Editor and Text Editor)
Re: EMF Model Synchrinization with Multipage Editor (Tree based Editor and Text Editor) [message #180332] Sat, 30 September 2006 16:01 Go to next message
Kamesh Sampath is currently offline Kamesh Sampath
Ed and Eike,
I am able to successully integrate the WTP SED with my Editor . Lots of
redundant stuff has been removed from the common TextEditor that we
develop. But am facing a peculiar problem with the same , whenever we
want to fire the PROP_DIRTY with StructuredTextEditor(WTP Text Editor)
we need to implement the Property Change listener and register the same
with WTP SED , when i do a == comparison between the source and my
initialised text editor inside my propertyChanged(Object source, int
propId) is failing , though when i print the same in the console its
same object name
* (non-Javadoc)
* @see
org.eclipse.ui.IPropertyListener#propertyChanged(java.lang.O bject,
* int)
public void propertyChanged(Object source, int propId) {
System.out.println("Source : " + source + " propID :" + propId
+ "PROP_Dirty=" + IEditorPart.PROP_DIRTY);
System.out.println("Source Editor :" + sourceEditor);
switch (propId) {
case IEditorPart.PROP_DIRTY:
case IEditorPart.PROP_INPUT: {
if (source == sourceEditor) {
if (sourceEditor.getEditorInput() != getEditorInput()) {
System.out.println("2.1");
setInput(sourceEditor.getEditorInput());
Runnable runnable = new Runnable() {
public void run() {
firePropertyChange(IEditorPart.PROP_DIRTY);
postOnDisplayQue(runnable);
break;
Can you help me why its failing ??
Kamesh
Kamesh Sampath wrote:
> Ed and Eike,
> The WTP SED is cool one . We have something called the
> StrucutredTextEditor , we can use that i guess. I am just looking in
> to that option , once am successful i shall post the message.
> Thanks.
> Kamesh
>> Ed and Eike,
>> Thanks for further Information . Actually i thoght of looking in to
>> that .. Let me do it . If am successfull i shall contribue a patch to
>> EMF editor generation to have an Text editor that will edit the source .
>> Thanks for the info .
>> Kamesh
>> Eike Stepper wrote:
>>> Kamesh Sampath schrieb:
>>>> Ed,
>>>> Thats right ! thats y i sought to see the PDE Editor , but for my
>>>> requirement its quite complex hence i asked for somthing much
>>>> simpler. Will try the XSD editor.
>>> Doesn't WTP have an XML editor? I don't use it but I'd expect that
>>> they have text/model sync...
>>> Cheers
>>> /Eike
>>>> Thanks .
>>>> Kamesh
>>>> Ed Merks wrote:
>>>>> Kamesh,
>>>>> Probably the best you will get is pointers to existing source code
>>>>> (Eric Gamma's monkey-see-monkey-do principle) and it will
>>>>> typically be quite complex. The XSDEditor is a relatively simple
>>>>> (i.e., crude) example. It will reparse the text whenever the text
>>>>> changes. It uses an IDocumentListener with a delay to avoid
>>>>> responding to every key stroke. For the reverse, the command
>>>>> stack listener calls handleStructuredModelChange whenever a
>>>>> command has been executed, which serializes the resource in memory
>>>>> and updates the text in the text editor. This is quite a brute
>>>>> force approach, but should serve as a starting point.
>>>>>> Folks,
>>>>>> Am really trying hard to save a model by editing a raw text and
>>>>>> there by updating the MODEL . All my attempts are in vain .
>>>>>> My Scenario:
>>>>>> The editing domain and model is same for both the editors i mean
>>>>>> to say am sharing the same common EMF model.
>>>>>> I have an Multipage editor with two pages 1. TreeViewer to edit
>>>>>> the model 2. TextEditor to view the model source
>>>>>> I am able to view the changes made to the TreeViewer in the
>>>>>> TextEditor
>>>>>> but am struck up with the reverse scenario i.e when i make any
>>>>>> textual changes to the model in form text in TextEditor i should
>>>>>> synchronize that with the underlying model file , I am using the
>>>>>> XML editor created out of eclipse platform samples.
>>>>>> My issues are ,
>>>>>> 1. How to track the textual changes in the Text Editor?
>>>>>> 2. How to fire the model commands based on the Textual Changes?
>>>>>> I dont know how to do this ? can anyone help me please . I dont
>>>>>> mind even the model file gets corrupted as am not enforcing any
>>>>>> validations now , all that i want is to make both work in sync
>>>>>> changes to Model reflected in Source and Changes to source should
>>>>>> be reflected in model.
>>>>>> I am trying to do exactly like the PDE editor. I even saw the PDE
>>>>>> editor source but its really long and very confusing to me.
>>>>>> Any pointers will be really helpful.
>>>>>> Thanks.
Kamesh Sampath
Re: EMF Model Synchrinization with Multipage Editor (Tree based Editor and Text Editor) [message #180341 is a reply to message #180332] Sat, 30 September 2006 17:12 Go to previous messageGo to next message
Eclipse User
Kamesh,
Should use be using .equals verses ==?
> Ed and Eike,
> same object name
> * (non-Javadoc)
> * @see
> * int)
> switch (propId) {
> getEditorInput()) {
> public void run() {
> break;
> Kamesh
>> Ed and Eike,
>> Thanks.
>> Kamesh
>>> Ed and Eike,
>>> to EMF editor generation to have an Text editor that will edit the
>>> source .
>>> Kamesh
>>>>> Ed,
>>>> Cheers
>>>> /Eike
>>>>> Thanks .
>>>>> Kamesh
>>>>> Ed Merks wrote:
>>>>>> Kamesh,
>>>>>> code (Eric Gamma's monkey-see-monkey-do principle) and it will
>>>>>> text changes. It uses an IDocumentListener with a delay to avoid
>>>>>> memory and updates the text in the text editor. This is quite a
>>>>>> brute force approach, but should serve as a starting point.
>>>>>>> Folks,
>>>>>>> My Scenario:
>>>>>>> TextEditor
>>>>>>> My issues are ,
>>>>>>> should be reflected in model.
>>>>>>> PDE editor source but its really long and very confusing to me.
>>>>>>> Thanks.
Re: EMF Model Synchrinization with Multipage Editor (Tree based Editor and Text Editor) [message #204520 is a reply to message #180332] Thu, 15 November 2007 18:19 Go to previous messageGo to next message
Eclipse User
Originally posted by: vasanthv16.yahoo.com
Kamesh, Ed,
I know it has been over a year since the last post on this topic, but,
any updates on this? As of now, the generated EMF multipage editor still
lacks a source editor.
Vasanth
> Ed and Eike,
> same object name
> * (non-Javadoc)
> * @see
> * int)
> switch (propId) {
> public void run() {
> break;
> Kamesh
>> Ed and Eike,
>> Thanks.
>> Kamesh
>>> Ed and Eike,
>>> Kamesh
>>>>> Ed,
>>>> Cheers
>>>> /Eike
>>>>> Thanks .
>>>>> Kamesh
>>>>> Ed Merks wrote:
>>>>>> Kamesh,
>>>>>>> Folks,
>>>>>>> My Scenario:
>>>>>>> TextEditor
>>>>>>> My issues are ,
>>>>>>> Thanks.
Re: EMF Model Synchrinization with Multipage Editor (Tree based Editor and Text Editor) [message #204532 is a reply to message #204520] Thu, 15 November 2007 18:33 Go to previous messageGo to next message
Eclipse User
Vasanth,
It's highly unlikely that that without active contributors from the
community this issue will get addressed directly by the vanishingly
small EMF team. It would make a great EMFT component.
Vasanth Velusamy wrote:
> Kamesh, Ed,
> still lacks a source editor.
> Vasanth
>> Ed and Eike,
>> same object name
>> * (non-Javadoc)
>> * @see
>> * int)
>> switch (propId) {
>> getEditorInput()) {
>> public void run() {
>> break;
>> Kamesh
>>> Ed and Eike,
>>> Thanks.
>>> Kamesh
>>>> Ed and Eike,
>>>> source .
>>>> Kamesh
>>>>>> Ed,
>>>>> Cheers
>>>>> /Eike
>>>>>> Thanks .
>>>>>> Kamesh
>>>>>> Ed Merks wrote:
>>>>>>> Kamesh,
>>>>>>> simple (i.e., crude) example. It will reparse the text whenever
>>>>>>> the text changes. It uses an IDocumentListener with a delay to
>>>>>>> avoid responding to every key stroke. For the reverse, the
>>>>>>> command stack listener calls handleStructuredModelChange
>>>>>>> whenever a command has been executed, which serializes the
>>>>>>> resource in memory and updates the text in the text editor.
>>>>>>> This is quite a brute force approach, but should serve as a
>>>>>>> starting point.
>>>>>>>> Folks,
>>>>>>>> My Scenario:
>>>>>>>> mean to say am sharing the same common EMF model.
>>>>>>>> TextEditor
>>>>>>>> should synchronize that with the underlying model file , I am
>>>>>>>> using the XML editor created out of eclipse platform samples.
>>>>>>>> My issues are ,
>>>>>>>> Thanks.
Re: EMF Model Synchrinization with Multipage Editor (Tree based Editor and Text Editor) [message #204575 is a reply to message #204532] Fri, 16 November 2007 02:16 Go to previous messageGo to next message
David Williams is currently offline David Williams
On Thu, 15 Nov 2007 18:33:53 -0500, Ed Merks <merks@ca.ibm.com> wrote:
> Vasanth,
Well, it's make an even better component in the WTP Incubator! :)
But Ed's point is just as valid. It will take someone from the community several
months of full time work to put together all the pieces we have, which
we know is no volunteer-in-your-free-time sort of effort.
Re: EMF Model Synchrinization with Multipage Editor (Tree based Editor and Text Editor) [message #204591 is a reply to message #204575] Fri, 16 November 2007 05:56 Go to previous messageGo to next message
Eclipse User
--------------060404030403070404040004
David,
Trying to usurp EMFT contributors are you?! :-P
It would be very helpful for WTP to provide SSE in a form that's more
easily consumable (i.e., with minimal dependencies).
https://bugs.eclipse.org/bugs/show_bug.cgi?id=205892
I suspect that would require some fundamental restructuring that would
break APIs, so that's not so likely to happen even with contributor
involvement...
>> Vasanth,
<html>
<head>
</head>
David,<br>
<br>
Trying to usurp EMFT contributors are you?!&nbsp; :-P<br>
<br>
easily consumable (i.e., with minimal dependencies).<br>
<blockquote><a
href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=205892">https://bugs.eclipse.org/bugs/show_bug.cgi?id=205892</a><br>
</blockquote>
involvement...<br>
<br>
<br>
<blockquote cite="mid:op.t1vih2otac05ss@dmw2t23.ibm.com" type="cite">
<pre wrap="">On Thu, 15 Nov 2007 18:33:53 -0500, Ed Merks <a class="moz-txt-link-rfc2396E" href="mailto:merks@ca.ibm.com">&lt;merks@ca.ibm.com&gt;</a> wrote:
</pre>
<blockquote type="cite">
<pre wrap="">Vasanth,
</pre>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
</body>
</html>
--------------060404030403070404040004--
Re: EMF Model Synchrinization with Multipage Editor (Tree based Editor and Text Editor) [message #204597 is a reply to message #204591] Fri, 16 November 2007 08:12 Go to previous messageGo to next message
Nitin Dahyabhai is currently offline Nitin Dahyabhai
more
would
> involvement...
It's not likely to happen *soon*, but we're keeping it in mind.
Nitin Dahyabhai
WTP Source Editors
Nitin Dahyabhai
Eclipse WTP, IBM
Re: EMF Model Synchrinization with Multipage Editor (Tree based Editor and Text Editor) [message #204605 is a reply to message #204575] Fri, 16 November 2007 09:09 Go to previous messageGo to next message
Eclipse User
Given that a generated Source Editor cannot be expected in the immediate
future, what would the best way for me to implement it myself? Earlier
in this thread, Ed mentioned using IDocumentListener. Is that the way to go?
Vasanth
>> Vasanth,
Re: EMF Model Synchrinization with Multipage Editor (Tree based Editor and Text Editor) [message #204611 is a reply to message #204605] Fri, 16 November 2007 09:13 Go to previous message
Eclipse User
Vasanth,
I think so.
> immediate future, what would the best way for me to implement it
> myself? Earlier in this thread, Ed mentioned using IDocumentListener.
> Vasanth
>>> Vasanth,
>> community several
Previous Topic:Eclipse 3.4 M2 and WTP 3.0 M2 Update Manager Issues
Next Topic:Creating EJB project from EAR
Current Time: Sat May 25 12:51:42 EDT 2013
Powered by FUDForum. Page generated in 0.11374 seconds
