| Problem with JSP while using JBOSS [message #179791] |
Mon, 25 September 2006 06:41  |
Originally posted by: rajivkrpoddar.gmail.com
I created a dynamic web project with servlets and jsp pages in latest
Eclipse. When I try to run the project on server (JBOSS v4), I get the
following error -
org.apache.jasper.JasperException: Unable to compile class for JSP
Here, the servlets run without any problem. The error comes only while
accessing jsp files. Even when I try to deploy the project on Tomcat
server, it runs well.
| Re: Problem with JSP while using JBOSS [message #179833 is a reply to message #179791] |
Mon, 25 September 2006 11:07   |
Originally posted by: wknauf_NO_._INSIDE_hg-online.de
Hi Rajiv,
one guess: do you need Java5 features in your JSPs ? JBoss 4 initially only
supports Java 1.4 language features, there is one config parameter which
activates Java 1.5.
Hope this helps
Wolfgang
> following error - org.apache.jasper.JasperException: Unable to
| Re: Problem with JSP while using JBOSS [message #180037 is a reply to message #179833] |
Wed, 27 September 2006 05:29   |
Thanks for replying, Wolfang.
Though my jsp page doesn't include any java5 faeture, I'd set that config
parameter. Could you please tell me what is that parameter and where and
how can I set that?
| Re: Problem with JSP while using JBOSS [message #180061 is a reply to message #180037] |
Wed, 27 September 2006 09:46  |
Hi Rajiv,
the parameter can be found in
"\server\default\deploy\jbossweb-tomcat55.sar\conf\web.xml".
Search this line and uncomment it:
<!-- Uncomment to use jdk1.5 features in jsp pages
<init-param>
<param-name>compilerSourceVM</param-name>
<param-value>1.5</param-value>
</init-param>
Do you see any stacktrace with the Jasper exception ? Either as an errorpage in
your browser or in the servers log ?
Best regards
Wolfgang
> config parameter. Could you please tell me what is that parameter and
> where and how can I set that?
FUDForum. Page generated in 0.05421 seconds
