Home » Eclipse Projects » Web Tools Project (WTP) » more path questions
more path questions [message #175796] Mon, 31 July 2006 10:58 Go to next message
Eclipse User
Originally posted by: jwoofy.hotmail.com
Thanks to Larry's response last week, I have my other project's code
deployed appropriately now. However, I'm struggling with the classes that
the other project depends on. Here's an example:
WebProject (my servlet, jsp, etc)
+ src
+ WebContent
AnalysisProject (Java that WebProject's src calls. This project builds and
deploys fine)
+ src
+ ClassFolder_1
+ gnu.trove
+ ClassFolder_2
So now WebProject's J2EE Module Dependencies include AnalysisProject. This
works fine. There is an AnalysisProject.jar in the /lib directory. However,
my classes in AnalysisProject.jar call classes in my classfolder, such as
the gnu.trove classes. When I start Tomcast inside Eclipse, then point a
browser to the web site, Tomcat throws an error saying "gnu.trove.map not
found". The ClassFolder_1 classes are not in the AnalysisProject.jar.
I created a .jar with the ClassFolder_1 and ClassFolder_2 classes and added
it to my J2EE Module Dependencies. This solution did put a ClassFolder_1.jar
in the /lib directory. I verified that the .jar contained the necessary
classes. However, the class not found problem still occurred. I think the
problem is that AnalysisProject.jar does not have a path to
ClassFolder_1.jar.
I could use a release build of AnalysisProject.jar including the class
folders, but I lose the ability for that .jar to get built on the fly when I
make modifications to AnalysisProject.
How do I add AnalysisProject's dependencies to the the project?
Jeff
Re: more path questions [message #175909 is a reply to message #175796] Tue, 01 August 2006 11:34 Go to previous messageGo to next message
Larry Isaacs is currently offline Larry Isaacs
Jeff,
Are ClassFolder_1 and ClassFolder_2 additional Java source folders or
something else?
Larry
> + src
> + WebContent
> deploys fine)
> + src
> + ClassFolder_1
> + gnu.trove
> + ClassFolder_2
> ClassFolder_1.jar.
> Thanks
> Jeff
Re: more path questions [message #175933 is a reply to message #175909] Tue, 01 August 2006 12:21 Go to previous messageGo to next message
Eclipse User
ClassFolder_1 and ClassFolder_2 contain directory structures containing
..class files. When I build a AnalysisProject.jar for non-web deployment, I
include these folders in the .jar description.
In other words, I usually build AnalysisProject.jar as a stand alone
application. In Jar Packager's Specification Screen, I select them in the
"Select the resources to export:" panel. So those classes exist in
AnalysisProject.jar with their appropriate paths.
Best Regards
"Larry Isaacs" <Larry.Isaacs@sas.com> wrote in message
news:eansa4$5f8$1@utils.eclipse.org...
> Jeff,
> something else?
> Larry
>> that the other project depends on. Here's an example:
>> + src
>> + WebContent
>> and deploys fine)
>> + src
>> + ClassFolder_1
>> + gnu.trove
>> + ClassFolder_2
>> This works fine. There is an AnalysisProject.jar in the /lib directory.
>> However, my classes in AnalysisProject.jar call classes in my
>> classfolder, such as the gnu.trove classes. When I start Tomcast inside
>> Eclipse, then point a browser to the web site, Tomcat throws an error
>> saying "gnu.trove.map not found". The ClassFolder_1 classes are not in
>> added it to my J2EE Module Dependencies. This solution did put a
>> ClassFolder_1.jar in the /lib directory. I verified that the .jar
>> contained the necessary classes. However, the class not found problem
>> still occurred. I think the problem is that AnalysisProject.jar does not
>> have a path to ClassFolder_1.jar.
>> when I make modifications to AnalysisProject.
>> Thanks
>> Jeff
Re: more path questions [message #175950 is a reply to message #175933] Tue, 01 August 2006 12:40 Go to previous message
If you add just this "full" AnalysisProject.jar as a J2EE Module
Dependency and not the project, does it work?
Larry
> Best Regards
>> Jeff,
>> something else?
>> Larry
>>> + src
>>> + WebContent
>>> and deploys fine)
>>> + src
>>> + ClassFolder_1
>>> + gnu.trove
>>> + ClassFolder_2
>>> Thanks
>>> Jeff
Previous Topic:Deploying to OC4J doesn't work
Next Topic:Server Timeout on Startup
Current Time: Tue May 21 21:10:36 EDT 2013
Powered by FUDForum. Page generated in 0.01617 seconds
