Home » Eclipse Projects » Web Tools Project (WTP) » Library in dynamic web application
Library in dynamic web application [message #173092] Wed, 05 July 2006 10:08 Go to next message
Eclipse User
Originally posted by: tei.silbergrau.com
I am developing a web application that is based on other java projects
that hold some base classes. Additionally these base projects depend on a
Library that is installed as plugin in eclipse and provides JAR's as a
Library in the classpath of the base project.
How can I add this library to the classpath of the web application? Though
the base project exports the library and is included as a J2EE Module
Dependency the library is not loaded when I start the application.
Re: Library in dynamic web application [message #173194 is a reply to message #173092] Wed, 05 July 2006 13:38 Go to previous messageGo to next message
Larry Isaacs is currently offline Larry Isaacs
In J2EE Module Dependencies, you can use the "Add External JARs..."
button to include these kind of JARs in your web application. This
would involve specifying the full path to the JARs in the plug-in. You
could also use the "Add Variable..." button and define a variable that
covers most of the path to the plug-in. Then reference the JAR from
that variable.
Larry
> a Library that is installed as plugin in eclipse and provides JAR's as a
> Though the base project exports the library and is included as a J2EE
> Module Dependency the library is not loaded when I start the application.
Re: Library in dynamic web application [message #173296 is a reply to message #173194] Thu, 06 July 2006 06:01 Go to previous messageGo to next message
Eclipse User
Thanks for your anwser. This would be a workaround to solve my problem.
Will it be possible to include libraries in the future? Is there a feature
request in the bug database?
cheers
tOM
Re: Library in dynamic web application [message #173321 is a reply to message #173194] Thu, 06 July 2006 08:08 Go to previous messageGo to next message
Eclipse User
Originally posted by: gene.rockhoppertech.com
You cannot add a library and that stinks.
If you add a variable it will barf.
It only works if you add a jar directly. That stinks too.
3.2 callisto
> that variable.
> Cheers,
> Larry
>> on a Library that is installed as plugin in eclipse and provides JAR's
>> as a Library in the classpath of the base project.
Re: Library in dynamic web application [message #173430 is a reply to message #173296] Thu, 06 July 2006 15:05 Go to previous messageGo to next message
I'm not aware of a specific bug with this feature request, though I
believe there are some that imply that populating the web project's
WEB-INF/lib should be more automated.
The sticking point with this particular feature is that while in many
cases it may be appropriate to assume that an exported library in a
project should be included in a web project's WEB-INF/lib, if it depends
on that project, there are valid cases where it should not. Supporting
both cases and maintaining sync when changes are made to dependent
project's exported Libraries will likely make this a non-trivial feature
to implement. I don't know if anything is planned for WTP 2.0 in this
area, so feel free to add your request.
Larry
> feature request in the bug database?
> cheers
> tOM
Re: Library in dynamic web application [message #175225 is a reply to message #173321] Fri, 21 July 2006 08:51 Go to previous message
Frits Jalvingh is currently offline Frits Jalvingh
I fully agree! WTP deployment is completely useless for any reasonably
sized project. You might want to vote for
https://bugs.eclipse.org/bugs/show_bug.cgi?id=138648
perhaps that'll get it fixed...
Frits
> 3.2 callisto
Previous Topic:License Agreement with disabled "I Agree" button
Next Topic:Final testing for the WTP 1.0.3 release
Current Time: Fri May 24 16:06:01 EDT 2013
Powered by FUDForum. Page generated in 0.01777 seconds
