| Tomcat, deploys to system temp directory [message #173142] |
Wed, 05 July 2006 11:55  |
Originally posted by: tobias.domain.hidden.com
My application gets deployed to both
..metadata\.plugins\org.eclipse.wst.server.core\tmp0\
and
C:/DOCUME~1/Tobias/LOCALS~1/Temp/0-
The problem is that tomcat serves content from
C:/DOCUME~1/Tobias/LOCALS~1/Temp/0- while WTP updates changes to
I can't find a reference to C:/DOCUME~1 in any files within eclipse or
the workspace. I've reinstalled both Tomcat and Eclipse with a fresh
workspace, the same problem occurs every time. My project has worked
just fine under WTP0.7 and it appears to have been converted to a WTP1.5
project correctly.
Any tips on how to prevent this?
I'm running eclipse 3.2 WTP 1.5 Tomcat 5.5.17 on Windows XP.
| Re: Tomcat, deploys to system temp directory [message #173157 is a reply to message #173142] |
Wed, 05 July 2006 12:25   |
Tobias Mattsson wrote:
> and
> project correctly.
After removing these attributes from my context.xml it deployed
correctly again.
<Context
antiResourceLocking="true"
antiJARLocking="true"
debug="1"
I'm still interested to know what caused it. Assuming it's some kind of
locking issue that causes WTP to use a fallback route could it be
possible to have WTP tell me this?
| Re: Tomcat, deploys to system temp directory [message #173172 is a reply to message #173142] |
Wed, 05 July 2006 12:54  |
Larry Isaacs Messages: 1261 Registered: July 2009 |
With the Tomcat server stopped, add a new "dummy" file to the
application. With the server still stopped, select the Tomcat server in
the Servers view and then click the "Publish to the server" icon in that
view (the rightmost icon). You should see the new file appear under
".metadata\...". Does it also appear under "C:/DOCUME~1/..." as well?
I'm not aware of any reason it should. If not, try starting Tomcat to
see if it is responsible for making the copy under "C:/DOCUME~1/...".
Larry
> and
> project correctly.
FUDForum. Page generated in 0.01599 seconds
