Home » Modeling » M2T (model-to-text transformation) » Code generation for the UML
| Code generation for the UML [message #15867] |
Thu, 10 May 2007 13:02  |
Andrew Carton Messages: 104 Registered: July 2009 |
I was wondering if anyone could point me towards some kind of M2T tool
support that would enable me to generate code from a UML 2 model (EMF
based). Is JET2 suitable for transforming UML2? I had a quick look at a
tutorial and it appears to be based on XML (XPath etc.), so I was
wondering if tools are advanced enough yet to allow the generation of
UML 2 models, at the same abstraction. I don't want to create a
dependency on a specific XMI representation as that specification might
change with later updates to the library. In particular, I need support
for behavioural transformations. Would mapping from code (via the UML2
libraries) be the easiest solution?
If anyone could offer advice on this for possible alternative solutions
I would be grateful.
Andrew.
| Re: Code generation for the UML [message #15885 is a reply to message #15867] |
Fri, 11 May 2007 09:04   |
Paul Elder Messages: 844 Registered: July 2009 |
Andrew:
JET2 can read UML models. Some tips:
1) XPath child steps: $someVar/aChildStep or $someVar/child::aChildStep
attempt to match 'aChildStep' to a UML2 feature name. For example,
$aUMLClass/type/@name would access the 'type' feature of Class (and then
return its name).
Failing a feature map, the XPath engine will attempt to use the step name as
an EClass name, and match any instances with-in the parents contents. For
example, $aUMLPackage/Class would match all Class instances (but not
subclasses). This can be quite useful in a massive meta-model such as UML2.
2) There is no special support for UML profiles, so accessing profile
attributes is not obvious. The best approach I can think of is to write some
custom XPath functions.
BUT, A BIG WARNING!
Although JET can read UML models, in the observing the development of many
UML-to-XXX transformations, it has been generally better to factor the
problem into two parts:
1) Create a code generator (with JET, if you like) that is fed by an
intermediate model that exposes only the elements of interest to the code
generator. Typically, this model is also structured to make code generation
easy.
2) Create a UML to intermediate model transformation, and, as a last step,
invoke the code generator.
This approach has a number of advantages:
1) Code generator creation is often best accomplished as a bottom-up
exercise: create a reference output for the code generator, and create
templates and an intermediate model that generates it.
2) UML is a massive meta-model. The exercise of determining how to represent
concepts needed by your code generator is not trivial. In fact, there may be
several valid representations. Determining this mapping independently of the
actual code generation has proved very useful.
Hope this helps, and thanks for considering JET.
Paul
"Andrew Carton" <cartona@cs.tcd.ie> wrote in message
news:f1vj7f$vmc$1@build.eclipse.org...
> wondering if tools are advanced enough yet to allow the generation of UML
> 2 models, at the same abstraction. I don't want to create a dependency on
> a specific XMI representation as that specification might change with
> later updates to the library. In particular, I need support for
> If anyone could offer advice on this for possible alternative solutions I
> would be grateful.
> Andrew.
| Re: Code generation for the UML [message #15974 is a reply to message #15867] |
Mon, 14 May 2007 10:25   |
Vladimir Sosnin Messages: 19 Registered: July 2009 |
Junior Member |
Hello, Andrew,
Seems like the only support JET needs to support UML is convenient query
and iteration tag. For this purpose I developed a simple plugin for JET
that allows to query UML models using OCL expressions. This plugin uses
Eclipse OCL plugin as engine. After getting UML element you can inspect
it using method used for access content of EMF models. It was enough for
me to get UML models transformed into things I needed.
Example:
<ocl:iterate query="Class.allInstances()->select(c |
c.parents()->exists(name='Number'))" var="umlClass" >
UMLClass: <c:get select="$umlClass/@name"/>
Parents: <ocl:iterate query="self.parents()" var="par"
modelroot="$umlClass"><c:get select="$par/@name"/>, </ocl:iterate>
</ocl:iterate>
I haven't published this plugin but it's pretty simple (<200 lines).
Vladimir
Andrew Carton wrote:
> Andrew.
| Re: Code generation for the UML [message #16105 is a reply to message #15974] |
Thu, 17 May 2007 08:38   |
Vladimir:
This is very cool. Would you consider contributing it to JET?
Paul
"Vladimir Sosnin" <antiso@gmail.com> wrote in message
news:f29rho$6gp$1@build.eclipse.org...
> Hello, Andrew,
> Example:
> </ocl:iterate>
> Vladimir
>> Thanks,
>> Andrew.
| Re: Code generation for the UML [message #16973 is a reply to message #16105] |
Sun, 20 May 2007 16:51   |
Junior Member |
Yes, I consider it. Could you please provide me with a starting point(s)
for contributing it to JET?
Vladimir
Paul Elder wrote:
> Vladimir:
> Paul
>> Hello, Andrew,
>> Example:
>> </ocl:iterate>
>> Regards,
>> Vladimir
>>> Hi,
>>> Thanks,
>>> Andrew.
| Re: Code generation for the UML [message #17064 is a reply to message #16973] |
Tue, 22 May 2007 09:44   |
Vladimir:
A contribution from a non-committer must follow the Eclipse Legal Process.
Although it seems complex, the goal is to ensure that code contributed to
Eclipse is 'clean', and will not create legal risks for the Eclipse
Foundation, its members or users. The contribution process is summarized in
the Eclipse Legal Process poster:
http://www.eclipse.org/legal/EclipseLegalProcessPoster.pdf
As you can see, there are many paths through the process. I think the first
questions to ask are:
1) Did you write the code yourself from scratch?
2) Do you have the right to contribute it to Eclipse? The answer to the
second question may depend on your employment contract.
3) Is the code being contributed under the Eclipse Public License (EPL)?
The process can tolerate answers other than 'Yes'; a 'no' just means more
time and process to follow.
If you want to proceed, contact me by e-mail, and we can figure out together
what steps to take first.
Paul
news:f2qcd2$nf8$1@build.eclipse.org...
> Vladimir
> Paul Elder wrote:
>> Vladimir:
>> Paul
>>> Hello, Andrew,
>>> Example:
>>> </ocl:iterate>
>>> Regards,
>>> Vladimir
>>>> Hi,
>>>> Thanks,
>>>> Andrew.
| Re: Code generation for the UML [message #17301 is a reply to message #15867] |
Fri, 25 May 2007 15:11  |
Originally posted by: carrasco.ModelDrivenDevelopment.co.uk
Indeed, MOFscript,
http://www.eclipse.org/gmt/mofscript/
http://modelbased.net/mofscript/
With syntax assisted editor.
Runs on any EMF models and UML.
I just love it, and develop in no other Model to Text language.
Cheers!
ACV
> would be grateful.
> Andrew.
Current Time: Fri May 24 14:02:21 EDT 2013
Powered by FUDForum. Page generated in 0.01781 seconds
