Home » Eclipse Projects » Web Tools Project (WTP) » Drag and drop problem in XML View
Drag and drop problem in XML View [message #169555] Thu, 18 May 2006 02:58 Go to next message
Eclipse User
Originally posted by: nandugud.nokia.com
Hi All,
I tried to drag and drop some elements in the XML outline view.
There seems to be a problem in the XML treeviewer as the changes are not
reflected immediately. But the changes are being reflected in the editor.
Since I am using "XMLDragAndDropManager.addDragAndDropSupport(treeViewer);"
for my view , the same behaviour is seen.
Is there any solution for this.
I'm using wst plugin version 1.0.1 I am not sure of this version, but the
plugin name is
"org.eclipse.wst_1.0.1.v200602270930.jar".
Anand
Re: Drag and drop problem in XML View [message #171258 is a reply to message #169555] Thu, 15 June 2006 03:32 Go to previous message
Nitin Dahyabhai is currently offline Nitin Dahyabhai
Anandatirtha wrote:
> Hi All,
> plugin name is
Does it resemble the problem as described in this bug report:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=134221 ?
- Nitin
Nitin Dahyabhai
Eclipse WTP, IBM
Previous Topic:Help with Hello World on WTP 1.0.2
Next Topic:How do I work around "Unsupported Content Type" error for HTML
Current Time: Tue May 21 19:55:58 EDT 2013
Powered by FUDForum. Page generated in 0.01474 seconds
