Home » Eclipse Projects » Web Tools Project (WTP) » JSP editing
JSP editing [message #162287] Mon, 27 February 2006 14:41 Go to next message
Eclipse User
Originally posted by: mark.mwilden.com
I can't seem to get Eclipse to use a JSP editor to edit *.jsp with WebTools
1.0 (or 1.0.1). When I right-click on a *.jsp file, JSP Editor is not listed
in the Open With... choice. And, of course, there is no syntax highlighting
when a JSP file is opened.
Any tips on how I might investigate this?
///ark
Re: JSP editing [message #162295 is a reply to message #162287] Mon, 27 February 2006 14:47 Go to previous messageGo to next message
Eclipse User
"Mark Wilden" <mark@mwilden.com> wrote in message
news:dtvkll$er2$1@utils.eclipse.org...
>listed in the Open With... choice. And, of course, there is no syntax
>highlighting when a JSP file is opened.
I just noticed that in Preferences, there is no JSP section under Web and
XML. Given this, it appears that I'm missing a plug-in (although JSP Editor
is listed as a choice in File Associations). Does someone know off-hand what
plug-in contains the JSP Preferences section?
///ark
Re: JSP editing [message #162326 is a reply to message #162295] Mon, 27 February 2006 19:08 Go to previous messageGo to next message
Eclipse User
news:dtvkvj$gie$1@utils.eclipse.org...
> Editor is listed as a choice in File Associations). Does someone know
> off-hand what plug-in contains the JSP Preferences section?
As another data point, I've found that the situation is workspace-related.
If I create and open a new workspace, everything works fine.
Re: JSP editing [message #171081 is a reply to message #162326] Mon, 12 June 2006 18:24 Go to previous message
Nitin Dahyabhai is currently offline Nitin Dahyabhai
If you installed WTP manually instead of using the Update Manager,
you might have to restart eclipse with "-clean" ensure that it is
properly detected.
- Nitin
Nitin Dahyabhai
Eclipse WTP, IBM
Previous Topic:getting error restarting war application
Next Topic:Ask again - Failed deployment on Oracle Application server
Current Time: Fri May 24 06:41:33 EDT 2013
Powered by FUDForum. Page generated in 0.09417 seconds
